Argue away..
- Used the probe compensation signal
- Horizontal, vertical, math scale, type of filter and cutoff settings don't affect the result.
Start cursor at the leftmost, end cursor does - NOT - effect the filter. Move the start cursor on right and the trace is shifted right, like it was before the update.
Then keep moving it right and after about 1 div it starts limiting the filter area. (note: it's the point where the correctly positioned trace starts.)
note how the filtered trace changes: it's not blanking what's before, it seems like it starts filtering from that point, right?
i think i'd say it's the correct behaviour (or at least the one i'd expect) but then why not show the complete trace from the start? the appereance should be the same, right?
update on "invert" bug, the bugged portion is what's on the right of the END marker
