Ok, how about one of these Breakout Boxes to enable the scope to access nice probe points so the scope could monitor the flow of communications between two PCs? (It would require two DB25 to DB9 adapter cables.)
PC RS232 port - DB9 Cable to DB 25 Adapter cable - Breakout Box - DB 25 to DB9 Adapter Cable - PC S232 Port
The DS1000Z could probe the Breakout Box? (I think the jumper cable connection points near the switches could be viable probe points, right?)
Seems like the LEDs on the box might provide some value-added info (and the switches and jumper cables might provide some extra flexibility). The box sells for about $25. Anyone have any experience with one of these? Or maybe someone has a better way of providing a scope with wire by wire tap points into a live RS232 communications flow?
Thanks!
Pocket-Sized RS-232/Serial Break Out Box
RS232 is a data signal standard used in many computer serial ports for connection between terminals and data communications equipment, such as modems and other communications devices. These boxes are pocket-sized for convenience and easy transportation, providing you with an on-the-go RS232 break out and testing solution. Furthermore, the box features 24 switches for circuit break out and reconfiguration/patching of 24 active positions. Using these boxes, you can enjoy the highest quality connection testing and configuration experience that only superior boxes can deliver.
Typical Applications:
RS232 circuit break out.
RS232 reconfiguring/patching.
RS232 signal, wire, and circuit testing/monitoring.
Features:
Access to all RS232/V.24 circuits
Twelve LED's to monitor key circuit isolation
Test points on each side of the switches to enable cross patching with jumper leads
Device is used to test and rewire RS232 interface. Put the RS232 connector cable that comes out of the box and plug it into the port of the interface card.
There are 10 interface signal powered LED's to permanently monitor TD, RD, RTS, CTS, DSR, CD, TC, RC, DTR, (E)TC and two LED's for spare.
24 miniature switches enable you to break out circuits or reconfigure and patch any or all of the 24 active positions.
No extra power required.
20 piece jumper cables included.
