the DS2072 has the same bandwidth as the DS2102 (100MHz)
The Rigol factory might change it in future, who knows.
they can't change that, the bw is controlled by LMH6518, you can set the it only to following values:
20, 100, 200, 350, 650, 750MHz and full (900MHz).
From measurments i collected the DS0272 model seems to be set to 100MHz, the DS2202 to 350Mhz, however there is some gain loss in the other part of the fronend, so total bw at -3dB for 200MHz models is 220-250MHz. I have no information from DS2102, so they could be set to 100Mhz (as the DS2072) but as well to 200MHz. With the extra gain loss this means they by -3dB at ~150MHz, however that my thought and not confirmed by any measurments.
