Author Topic: Tektronix 2201 - 70­­€ good price?  (Read 2530 times)
Offline acinhoTopic starter
  • Country: si
« on: July 12, 2016, 02:40:24 pm »
Is 70€ a good price for Tektronix 2201?
Thanks!
Offline Fungus
Re: Tektronix 2201 - 70­­€ good price?
« Reply #1 on: July 12, 2016, 02:55:31 pm »
Does it work? Is it in good condition? Does it have probes/accessories/manuals? Do all the controls work?
Does it do what you need? Is 20MHz bandwidth enough? (unlikely)
$70 is a high price for anything if it doesn't do the job.
The following users thanked this post: acinho
Offline David Hess
  • DavidH
« Reply #2 on: July 12, 2016, 09:29:41 pm »
If availability of similar instruments is limited in Slovenia, then I would say it is a reasonable price (70€ is about $78 US) assuming it works and is in good shape.  Can you inspect it before buying or will it be shipped to you?  The 20 MHz bandwidth will be limiting for many applications.
Artek Manuals has the service manual available:
http://artekmanuals.com/manuals/tektronix-manuals/
  • Country: si
« Reply #3 on: July 12, 2016, 10:05:18 pm »
Prices here are ridiculous.
It'll be shipped from abroad but pictures do show a square signal. Probes are included and it's calibrated.
20MHz will be enough for my project.
Offline David Hess
  • DavidH
« Reply #4 on: July 13, 2016, 04:13:15 am »
That is what I thought; I know from reports that availability of used test equipment or at least old Tektronix oscilloscopes is much poorer outside of the US.  If you have something shipped in, then you risk shipping damage if the seller does not pack it correctly.
We do not see much about the 2201 or even the 2225 series which it is part of over on TekScopes@yahoogroups.com but I do not know of any common problems with them; their design is a major refinement of the older and faster 2235 series and easy to repair and maintain.  The 20 MHz 2201 and 2205 lack the x10 vertical magnification for 500uV/div sensitivity which make the faster 50 MHz 2210, 2211, and 2225 unique in their class but if that is not a requirement then so what?  20 MHz and 5mV/div is completely suitable for most applications.
Since the service and operating manual is available inexpensively, that is not an objection either.
Update: you can find the manuals for the 2205 which is the same oscilloscope without the storage functionality here:
http://w140.com/tekwiki/wiki/2205
« Last Edit: July 13, 2016, 04:16:25 am by David Hess »
