Author Topic: New Rigol DHO5000 8-ch. Oscilloscope 10.1" 12-bit 4GSa [500MHz & 1GHz]  (Read 367 times)
Online DaneLawTopic starter
Support Bluetooth & WIFI, alongside a connector for a hooked-on battery-pack, same as Rigol DG5000PRO signal gen.
10.1" screen [1280x800] Seems quite limited for a new modern scope with 8 analog channels when we are up in this 5-digit price bracket.
A 10-inch 800p screen is not a lot of screen real estate for all those analog channels on a UI that is heavily window-optimized.
Price level in China: DHO5058/500MHz around 11.000 $  [79.800CNY) DHO5108/1GHz 14.000$ (99.800CNY)
Details
https://www.rigol.com/products/detail/DHO5000
Datasheet (CN)
https://download.rigol.com/en/Manual/Digital%20Oscilloscope/DHO5000/DHO5000_DataSheet.pdf
« Last Edit: Yesterday at 01:41:16 am by DaneLaw »
The following users thanked this post: egonotto, thm_w, RAPo
Also a new revision of their DS70000 flagship StationMax, under the new label DS80000. [13GHz, 40GSa, 4Gpts]
Product Details (CN)
https://www.rigol.com/products/detail/DS80000 (ENG-BOT vers. below)
« Last Edit: Yesterday at 06:04:37 am by DaneLaw »
Online maxwell3e10
Looks like a copy of DHO4000 with twice the number of ADCs for four times the price.  Now if they took DHO1000 and doubled the number of channels for double the price (around $2k), it would be an interesting product.
Offline Sensorcat
  • Freelance Sensor Consultant
    • Sensorberatung
I understand that the front is sort of crowded with 8 channels, but where is the probe compensation output? Do I have to have a 2nd scope to check my probes when using a DHO5000?
Offline Construct
Right side. In the Horizontal controls section.
Looks recessed to stay mostly out of the way.
