Hey, can you confirm, that PS is indeed so ridiculously deep (41cm)?
It is quite ridiculous, yes. Second only to my full-size rackmount multimeters.
Can these gray rubber corners be removed?
Can you measure real depth of bare case, not taking into account front panel connectors and these rubber things?
The rubber corners can be removed. A couple screws hold on each of the front ones, and one on each of the back ones. All metal threaded inserts, too! The unit itself doesn't have any rubber feet, though.
The depth of the bare case is about is about 38cm. Add 2.5cm to the front for the binding posts, and about the same to the back for the power connector. At least in the US where I bought mine, the IEC connector is right angled, so you can scoot it right up against a wall or something.
Actually, the binding posts stick out further than the rubber corners.
Any comments on fan noise? When used at home, fans can be really annoying...
Fan noise is actually somewhat annoying. Nowhere near as bad as most of the cheap power supplies I've seen, but definitely a bit louder than my Rigol DS1052E, which I'd probably rate as on the verge of annoying. Its also much more of a hum than a whirr, if you know what I mean. The fan does seem to be temperature controlled, but it doesn't completely turn off with no load.
Overall, after watching photos for 10 minutes, I start to like the design
DP832 looks even quite professional with monochrome UI and all the buttons being grayish.
Especially function buttons under display looks out of the place...
DP832 looks like real bargain for $400, but my bench is only 32cm deep
Design certainly isn't bad. There are a handful of quirks about the UI which I wish Rigol would update/change, but its easy to get used to it. It also looks much more professional without the rubber corners. It's too bad your bench is too short, because I'd definitely recommend this as a decent programmable power supply, especially for the price.
