Well, after waiting a little over 4 months from the time I ordered to delivery. I finally have my new DP832A! I haven't done any serious testing with it yet, but I did hook it up and play a little this afternoon. So far, I haven't found anything too egregious. It seems like a fairly high quality unit.
It came with a nice (but thin) shorting bar, and 3 (count 'em THREE) fuses. Nice touch, and certainly unexpected from a Chinese import. I'm kind of surprised I even got one. The quick-start guide and PDF manual aren't too shabby either, at least if you consider where they came from.
Under normal loads (well, normal for me) the fan is actually significantly quieter than my Rigol DS2102, and only a little louder than the scope when running full bore on all 3 channels. I was expecting its fan to be much louder, but I was pleasantly surprised.
One odd thing I noticed is that in CC mode, it is overshooting by 100% when you turn the output on. But, it's back to the proper voltage after about 300 us. The 100% overshoot might have something to do with the extremely low value resistor I'm using as a load (It's the best I could do with the scraps in my junk drawer) and the tiny voltages it needs to hit the CC limit. Maybe if I was looking for 10V instead of 0.1V to hit the CC limit, the overshoot wouldn't be so bad. I'll have to check it out if I can find an appropriate value power resistor to use as a load.
EDIT: I found a larger value power resistor. The overshoot seems to have been from the extremely low voltage required to get to the CC limit. There is no overshoot at all (that I can see with my scope) when powering on now. Since it would be unlikely that I would be powering anything that looks like a <1Ohm load with this PSU, it's probably not a big deal at all.
It's voltage setting and read-back seem to be spot on. Or at least it's close enough that I can't measure the error with my 87V. I'm within 1mV in absolute terms, and relative changes are perfect. I haven't attempted any external measurements of current yet.
The UI is wonky. The triangular 3-way display is odd to say the least. But, I do like the color coding for the waveform display; it changes the background to the color for whatever channel is currently selected. I probably shouldn't have sprung for the A-model, but when I ordered it the only pictures I could find of a non-A model had a red display, and I'm red-green colorblind so that wasn't going to work. Only recently have I discovered that you can change the colors on the non-A version.
Oh well. I'm pretty sure it won't take long to get used to, but if I were to do it again I might go for a fully upgraded non-A model over the 832A. The other minor UI gripe is that the display for setting the voltage and current is so small it's hard to read unless you are very close to the display. My typical use case will be to set it and forget it, so it's a minor annoyance to me.
I discovered there's a Display->Custom GUI menu that asks what file to load from USB storage. It got my hopes up that maybe I'd be able to change the layout of the GUI. Unfortunately, after consulting the manual, it appears that you can only add custom graphics to the boot-up screen that says "Rigol." You can't change anything else.
So far I'm impressed and I think it's a fine unit for the money. I don't have the expertise to conduct a thorough test of the unit, or to do a proper write-up/review, but I figured I'd probably better post some sort of initial impressions because the product is so new, and so few people have one yet. Honestly, I'm dangerously under-qualified to be telling people if this thing is good or not, so take anything I've said with a boulder of salt. But, what's the Internet for if not to read the opinions of noobs?
