Author Topic: New Rigol DC Load DL3000 Series  (Read 83503 times)
Offline smithnerd
Re: New Rigol DC Load DL3000 Series
« Reply #50 on: June 10, 2017, 06:23:48 pm »
I noticed a couple of things while I was poking around in the GEL firmware update file:
Mention of a DAC8560 voltage reference:
http://www.ti.com/product/DAC8560
Mention of two other models, 3051 and 3051A - a future/canned 500W version?
Offline Dubbie
« Reply #51 on: June 10, 2017, 06:53:13 pm »
If you ask me, I'd be more concerned about the noise injected from the unit rather than the price itself: it's very annoying to have your measurement screwed up by things like that... Especially if you are going to make some ripple measurements or specification checks on other power supplies! Anyway, for less than 800 Eur it would be a fantastic choice for most of us!
Agreed. This is my main concern. My iTech is noisy as anything and also can't go down below about 10mA reliably. If this thing would be quiet and precise, I would look at replacing. Yes, an SMU would be better, but is 10x the price.
Offline R005T3r
« Reply #52 on: June 11, 2017, 10:25:34 am »
500W upgradeable by software license maybe?
Offline simone.pignatti
« Reply #53 on: June 12, 2017, 11:14:18 am »
it seems the DL3000 comes in two different color schemes:
non-A models
A models
Technical Support
Offline pascal_sweden
  • Country: no
« Reply #54 on: June 12, 2017, 01:44:33 pm »
A models have an A-mazing look :)
Offline tooki
Re: New Rigol DC Load D3000 Series
« Reply #55 on: June 12, 2017, 02:18:33 pm »
And a photo from Batterfly :
https://twitter.com/BatterFlySrl/status/841943973321179136
Off-topic comment after I saw the Twitter photo you posted: what's with Rigol and their PSU GUIs emulating low-contrast LED displays? As if faking a 7-segment display using high-resolution graphic LCD wasn't silly enough, they even mimic the still visible "off" segments for added non-legibility :palm:
EDIT:
Or was the LCD "persistence" of the power readout just the effect of the unfortunate timing and/or long exposure?
I absolutely hate when designers mimic 7-segment displays. It makes no freaking sense. As a UI designer, you want it to be as usable as possible, so you should be choosing fonts that maximize legibility.
I sure as heck hope the "off" segments there are an artifact of photography, and aren't actually present. My guess is that it's an artifact, since the two upper display areas don't seem to have it at all.
« Reply #56 on: June 12, 2017, 02:21:53 pm »
tooki, I have a DL3021 here on my desk, please tell me what you like to see and I take a picture and post it.
Technical Support
Offline Aeternam
  • Country: lu
    • Schartz Engineering
« Reply #57 on: June 12, 2017, 02:46:34 pm »
How about a teardown?  ;D  :-+
The following users thanked this post: AgiRigSig
Offline mcinque
  • I know that I know nothing
« Reply #58 on: June 12, 2017, 06:11:37 pm »
Naturally!!  :-+
Offline SimonDTopic starter
« Reply #59 on: June 13, 2017, 07:46:09 am »
Naturally!!  :-+
Great idea !!!
Simone,
i m ready to pull the trigger for the DL3021  :P,  my application needs 24V at 25A ... 35A, can you make a quick test in this range please ?
P.S. (at Simone), any discount code as you have say in to the SDM3065X topic ?    ;)
  • Country: no
« Reply #60 on: June 13, 2017, 08:31:10 am »
Maybe you can try RIGOL-123-PASTA, or RIGOL-MAMA-MIA? :)
Offline tooki
« Reply #61 on: June 13, 2017, 09:59:51 am »
It's not clear from my reply, or the original comment I was replying to??
Look at the picture in:
See how on the watts display, the unlit segments are still kinda lit? (And on the V to a lesser degree.) Are the unlit segments actually there but less bright, or are they actually completely black, and what the picture shows is just artifacts from photography?
Online ebastler
« Reply #62 on: June 13, 2017, 11:09:53 am »
So you are not wondering about the DL3021 load at all, but about the DL700 power supply which sits on top of it in the photo, right?
Offline Kleinstein
« Reply #63 on: June 13, 2017, 11:30:33 am »
I would expect the half lit segments on the power supply to be an artifact from changing numbers during exposure.
Offline tooki
« Reply #64 on: June 13, 2017, 12:31:19 pm »
I wasn't wondering at all. Just agreeing with/elaborating on someone else's comment.
Online ebastler
« Reply #65 on: June 13, 2017, 01:03:26 pm »
Sure. But you were asking for details on the DL700 (the instrument sitting on top in the Batterfly photograph, with the simulated 7-segment display).  In contrast, simone.pignatti had offered to take pictures of his DL3021, and probably does not have a DL700. Just trying to clarify...
« Last Edit: June 13, 2017, 01:05:38 pm by ebastler »
« Reply #66 on: June 13, 2017, 01:44:48 pm »
LOL
We have discount code, just send a PM, we will try to make a funny one :)
Technical Support
« Reply #67 on: June 13, 2017, 01:48:05 pm »
Sorry if I messed up...
Yes we have  DP711 and DP712 to try together with the DL3021
Now I'm traveling, I can do from next Monday on
tooki, sorry again
ciao
Technical Support
Offline maukka
« Reply #68 on: June 13, 2017, 03:21:00 pm »
Thanks to Simone(?) for answering my question on Youtube about the watt-hour display (which I totally think they should include in the battery test display). I also edited my second question and wasn't sure if you noticed that. I went through the manual, but can't confirm whether it's possible to log csv data on a USB flash drive.
« Reply #69 on: June 13, 2017, 04:10:27 pm »
I'm not sure you can download straight from the unit to a USB stick
However the Rigol Ultra Load PC Software is free of charge, you can get it here:
https://beyondmeasure.rigoltech.com/acton/attachment/1579/f-0781/1/-/-/-/-/S1501%20Ultra%20Load%28PC%29Install_00.01.00.02.zip
Technical Support
Offline Dubbie
« Reply #70 on: June 14, 2017, 04:34:18 am »
I am really hoping they release a new power supply with this new case and screen design.
Would be a big improvement over the old one.
  • Country: no
« Reply #71 on: June 14, 2017, 06:16:52 am »
And hopefully all 3 voltage outputs will be completely isolated like on the Siglent power supply.
Offline Dwaine
« Reply #72 on: June 14, 2017, 06:47:01 am »
I hope Dave gets a unit and does a tear down of the A model.   :popcorn:
Offline tooki
« Reply #73 on: June 14, 2017, 08:37:26 am »
tooki, sorry again
ciao
Still, appreciative of your offer to help, even if I don't need it myself!  ;D
« Reply #74 on: June 15, 2017, 05:37:58 am »
I am wondering if two or more pieces can work parallel ... (via Digital I/O synchronization for example) as other manufacturer devices ...
« Last Edit: June 15, 2017, 05:47:57 am by SimonD »
