i followed this guide successfully down to step 3 and stack to 4. yes i run the unzipped script in 1.08
As I have just successfully upgraded my DG812 to DG992 I would like to post yet another summary of the required steps.
0. Note your DG's serial number if you care.
1. If you have software version higher than 00.01.08.xx.xx you need to downgrade to version 1.08 using specially modified GEL file to allow downgrade (as described by evgbog here:
https://www.eevblog.com/forum/testgear/new-rigol-16-bit-function-generators-dg800900-series/msg3017342/#msg3017342).
My contribution is that I've prepared modified GEL file, available here:
https://drive.google.com/file/d/16nC-uJ12MXilJElv4Eukvt1IW4RzGdb7/view?usp=sharingPut the file on USB stick, plug it into your DG and accept "update" when popup shows. WARNING! This "upgrade" will reset your SN to DG80000000001 but convert your unit into DG992 immediately. This is the effect of the downgrade itself - the firmware is official Rigol firmware. The modification only changes the boot script to allow downgrade.
As a side note, I don't see a point in using hex editor in evgbog method of preparing the GEL. Those GELs are tar files as mentioned by tv84. I prepared the file by simply untaring it, decrypting fw4uboot.sh, modifying it, encrypting it back (you need to maintain file size) and finally TARing everything back into GEL file using 7zip.
2. Prepare a "magic" USB stick. Format USB stick as FAT32 (stick MUST BE BIGGER than 1GB). Open it in HxD editor as LOGICAL DISK (not physical disk - I did that mistake) Tools->Open Disk (uncheck "open as readonly"). Jump to sector 2000000 (sector field is at the top right corner). Enter value manually or use "Paste write" in edit menu (Ctrl+B). Magic value: 0B0A3B2E5F4CECBE
3. Insert the magic stick into DG (make sure it is recognized and USB icon is shown) and connect the instrument with the computer (using USB A-B cable and downloading Rigol's bloatware UltraSigma is the easiest way). Open SCPI command panel, check communication by issuing *IDN? command (use Send & Read). Send command :PROJ:SN DGxxxxxxxxxx with your correct SN number noted in step 0 (use Send command, DO NOT USE Send & Read). Verify if it worked by sending another *IDN? command - it should report back with correct serial number. Now send command :PROJ:MODE DG992. You can disconnect the instrument from PC and remove USB stick.
4. Edit: This step is only needed if your purchase version was higher than v1.08 and you did step 1 Download tv84's "Finish_Upgrade_2.04.zip" from this post:
https://www.eevblog.com/forum/testgear/new-rigol-16-bit-function-generators-dg800900-series/msg3119264/#msg3119264Put this GEL file on USB stick, plug into DG and confirm update when popup shows.
5. Download official 2.04 firmware from Rigol:
https://int.rigol.com/Public/Uploads/uploadfile/files/ftp/DG/软固件/SardineII(ARM)Update-v00.02.04.00.00.rar
No logging in required
![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
Put GEL file on USB stick (delete the previous one), upgrade DG and enjoy
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
Serial number should be kept and model should be DG992.
All credits go to tv84, bulba99, evgbog and others who helped to create this hack!
