Author Topic: New Rigol 16-bit function generators DG800/900 series  (Read 211487 times)
Offline Martian Tech
Re: New Rigol 16-bit function generators DG800/900 series
« Reply #525 on: August 14, 2020, 07:14:32 pm »
Oscilloscope bandwidth is 100MHz
OK, that explains part of what you're seeing.  The bandwidth is the point at which the response drops to -3dB, so that is affecting your readings and giving more apparent falloff than is actually there.
Offline TK
« Reply #526 on: August 14, 2020, 07:21:48 pm »
Hello everyone!
My DG811 version is 00.02.04.00.00, and I upgraded to 992 according to the method provided by Vtech.
But the output voltage is very different. What is the reason?
What is the bandwidth of your oscilloscope?
Oscilloscope bandwidth is 100MHz,DS1074Z ↑ DS1104Z
I tested on my setup (DG811 -> DG992), GW Instek GDS1054B scope (50MHz -> 100MHz) and I get 1.2Vpp with HighZ, direct BNC to BNC connection
« Reply #527 on: August 14, 2020, 07:49:25 pm »
Also ignoring the high Z input, if that scope input is 18pf at 100Mhz that’s a reactance of 88 ohms approx so you’ve got a voltage divider against the 50 ohms source there as well as the 3dB bandwidth fall off to contend with.
Offline jscm2000
  • Country: cn
« Reply #528 on: August 15, 2020, 03:37:10 am »
Please advise, after upgrading to 992, will the sampling rate be 250MSa/s? Is the waveform length 16Mpts?
Offline TurboTom
« Reply #529 on: August 15, 2020, 07:59:48 am »
Yes and yes...  :) Read here and the few following contributions. Btw, 250MSa/s it always was, on all instruments throughout the range. There's been some inconsistency regarding this issue in Rigol's documentation/advertising.
The following users thanked this post: jscm2000
« Reply #530 on: August 17, 2020, 01:03:47 am »
A bit off the main topic of discussion, but just wondering if anyone else has tried operating one of these with an external timebase?  With mine, it runs OK for a while, then switches back to the internal timebase.  My source is a buffered OCXO, and the output voltage is within spec.  BUT I'm running 1.08 firmware - wondering if maybe upgrading to new firmware will fix it?
OK, I finally got around to acquiring a USB thumb drive that I could use to upgrade, so I can answer my own question.  Upgraded from 1.08 to 2.04 firmware, and the external reference works reliably now.
« Reply #531 on: August 17, 2020, 03:10:39 pm »
Is the DG811 hackable on all firmware revisions at the moment?
Offline TK
« Reply #532 on: August 17, 2020, 03:26:03 pm »
you need to downgrade from 2.04
« Reply #533 on: August 17, 2020, 03:26:38 pm »
Thanks. That's good enough for me.  :-+
Offline jscm2000
  • Country: cn
« Reply #534 on: August 17, 2020, 03:32:41 pm »
Latest firmware, not tested
The following users thanked this post: thm_w, bd139
Offline PushUp
« Reply #535 on: August 17, 2020, 09:31:05 pm »
You probably need a Chinese account - at least I could not login with my EU registration  :-// to get the download file... I always get a sad smilie!  :(
...nearly at the end of this site...
https://www.rigol.com/supports/software-firmware-download_2.html
Offline bulba99
« Reply #536 on: August 18, 2020, 08:28:18 am »
Only a Chinese mobile number is accepted during registration.
An SMS with a verification code is sent to this number.
A colleague from China would have to help.
Offline Vtech
« Reply #537 on: August 18, 2020, 08:52:19 am »
Here you go: https://rigol.com/Public/Uploads/uploadfile/files/ftp/EMD/DG/SOFTWARE/firmware/SardineII(ARM)Update_00.02.05.00.00.rar
No need to register - download link is present in javascript source code of the web page :-DD
EDIT: Release Notes: v00.02.05.00.00   2020-05-30
     - Solve the problem that the machine model changes to DG811 when upgrading to 00.02.04.00.00
I think there is no point of installing this.
« Last Edit: August 18, 2020, 08:55:19 am by Vtech »
Offline bulba99
« Reply #538 on: August 18, 2020, 10:05:15 am »
« Last Edit: August 18, 2020, 10:07:38 am by bulba99 »
Offline tv84
  • Country: pt
« Reply #539 on: August 18, 2020, 01:42:39 pm »
 :-DD
Offline bulba99
« Reply #540 on: August 18, 2020, 01:55:36 pm »
 :-DD
This behavior probably applies to the DG2000 family and therefore there is only firmware 02.02 for this series on most websites.   :D
« Last Edit: August 18, 2020, 02:43:51 pm by bulba99 »
Offline TK
« Reply #541 on: August 18, 2020, 02:57:56 pm »
Does anyone know the difference between DG992 and DG2102?  Can the DG811 be hacked to DG2102?
Offline tv84
  • Country: pt
« Reply #542 on: August 18, 2020, 03:06:16 pm »
DG2000 has LAN interface built-in.
Nobody has tried it. Disregarding the LAN difference it could be possible or...  Nonetheless, don't see any value in that.
The following users thanked this post: TK
Offline jscm2000
  • Country: cn
« Reply #543 on: August 20, 2020, 01:37:56 pm »
As far as I know, there are obvious individual differences in the DG800 series. Some 1Vpp can only reach 0.3 or 0.8. When you buy, it is best to filter if you have the conditions. I use a special method to make my DG811 reach the real DG992 standard. When 1Vpp, it shows 0.97Vpp. I will publish my test next time.
The following users thanked this post: thm_w, TK
Offline jscm2000
  • Country: cn
« Reply #544 on: August 23, 2020, 08:53:55 am »
Using special methods and calibration, the output amplitude of DG811 in the high frequency range reaches the standard. DG811 truly becomes DG992!
Offline tv84
  • Country: pt
« Reply #545 on: August 23, 2020, 12:38:27 pm »
 :-+ Now, it would be cool if you share your calib method.
Offline Gandalf_Sr
« Reply #546 on: August 24, 2020, 12:19:20 am »
What TV84 is asking is...
Please tell us how you did the calibration. What is your "special method"?
If at first you don't succeed, get a bigger hammer
« Reply #547 on: August 25, 2020, 08:45:07 pm »
Use a SDG6032X offscreen as "reference"...?  :-DD
 :bullshit:
The following users thanked this post: TurboTom
Offline tv84
  • Country: pt
« Reply #548 on: August 29, 2020, 07:47:18 pm »
DG800/900/2000 Performance Verification Guides.
« Last Edit: August 29, 2020, 08:14:46 pm by tv84 »
Offline SMB784
    • Tequity Surplus
« Reply #549 on: August 30, 2020, 02:33:51 am »
Is the performance verification guide for the various generators helpful in producing a correct calibration for a DG811 "upgraded" to a DG992?
