Author Topic: New Rigol 16-bit function generators DG800/900 series  (Read 205107 times)
Offline TurboTom
Re: New Rigol 16-bit function generators DG800/900 series
« Reply #425 on: April 26, 2020, 02:22:58 pm »
Well, it seems that @evgbog is the only one has FW 02.02 currently. Will you share it please?  :-+
You can download F/W 02.02 from Rigol's firmware download page. Use the DG2000 link which contains identical hardware as the DG800/900 series in a different enclosure. Also same "internal" designation: "Sardine"  ;)
The following users thanked this post: thm_w, klamath, stupiid, thetechnick
Online tv84
  • Country: pt
« Reply #426 on: April 26, 2020, 05:33:36 pm »
The following users thanked this post: klamath, stupiid, thetechnick, Powernun
Offline thetechnick
« Reply #427 on: April 26, 2020, 08:27:15 pm »
Just wanted to add:
When you have unlocked your device successfully and then upgraded to v00.02.04 (and lost the unlock),
you can still install the linked v00.02.02 update and your device will be unlocked again.
Somehow nothing prevents downgrading from v00.02.04 to v00.02.02  :-+
Thanks for posting!
The following users thanked this post: zhang011101, klamath, stupiid
Offline stupiid
  • Country: th
« Reply #428 on: April 27, 2020, 03:35:58 pm »
Thanks! Upgraded successfully. :clap:
Still waiting the hack to 02.04.  :popcorn:
Offline bulba99
« Reply #429 on: April 27, 2020, 03:40:29 pm »
@tv84,
what did you mean by "Possible model types (as seen in the first 4 bytes of sd.xx configuration file)"
in the DG800 manual ?
« Last Edit: April 27, 2020, 03:44:24 pm by bulba99 »
Online tv84
  • Country: pt
« Reply #430 on: April 27, 2020, 03:50:11 pm »
@tv84,
This is a file inside the DG which also has those "model numbers". But I think it's only informative. You cannot change model by only changing the file.
Offline bulba99
« Reply #431 on: April 27, 2020, 03:56:55 pm »
@tv84,
In DG firmware? In which part ?
Online tv84
  • Country: pt
« Reply #432 on: April 27, 2020, 03:58:25 pm »
"Inside the DG" means in its file system.
Offline bulba99
« Reply #433 on: April 27, 2020, 04:03:50 pm »
OK, do you need to make a file system dump?
If so, in what way ?
Or how can I browse this file system?
« Last Edit: April 27, 2020, 04:06:47 pm by bulba99 »
Online tv84
  • Country: pt
« Reply #434 on: April 27, 2020, 04:27:28 pm »
You do a NAND backup with the script that I placed in this thread and then browse through the appropriate mtd.
The following users thanked this post: bulba99
Offline bulba99
« Reply #435 on: April 27, 2020, 04:33:59 pm »
Everything is clear, thank you very much  :)
Offline Aztlanpz
« Reply #436 on: April 27, 2020, 06:06:20 pm »
can someone help me locate the firmware 1.08.01 for the DG800.  Thanks everyone I have located the file.
Thanks
Azltan
« Last Edit: April 27, 2020, 09:31:58 pm by Aztlanpz »
Offline bulba99
« Reply #437 on: April 27, 2020, 06:20:25 pm »
Thanks
Azltan
Last post on previous page, first point.
Online tv84
  • Country: pt
« Reply #438 on: April 27, 2020, 06:51:49 pm »
Can you try this:
You are in 2.02, right?  Upgrade to 2.04 and then send the SCPI command:
PROJ:SN <your_serial>
Reboot and report if there is any difference.
Online tv84
  • Country: pt
« Reply #439 on: April 27, 2020, 09:40:05 pm »
I finally had a look at the v2.04 FW.
It seems all these models are possible:
00 - DG811
01 - DG821
02 - DG831
03 - DG812
04 - DG822
05 - DG832
06 - DG952
07 - DG972
08 - DG992
09 - DG2012
10 - DG2022
11 - DG2032
12 - DG2012-E
13 - DG2022-E
14 - DG2032-E
15 - DG2052
16 - DG2072
17 - DG2102
I think the 800/900 is USB0::0x1AB1::0x643  and 2000 is USB0::0x1AB1::0x644.
The licensing scheme is the same as in previous versions. One can use the PROJ:MODIF to change the model.
BTW, can someone explain me what's the difference between a DG992 and a DG2102?  (to see if we should upgrade to DG2102)
« Last Edit: April 27, 2020, 09:41:51 pm by tv84 »
Offline thm_w
  • Non-expert
« Reply #440 on: April 27, 2020, 10:32:41 pm »
In terms of datasheet:
- Built in HW LAN, as mentioned
- Burst characteristics -> carrier frequency: 2mHz to 30MHz vs 2mHz to 100MHz
Not sure if thats a typo or an actual limitation.
edit: can already set 100MHz sine in burst mode, so I don't believe there is a limitation.
« Last Edit: April 28, 2020, 09:03:54 pm by thm_w »
Offline ultranalog
  • Audio Nerd - not an audiophool
    • It's only audio
« Reply #441 on: April 27, 2020, 11:16:41 pm »
I tried this and did not work, with or without the magic disk. I could 'up'grade back to 2.02.
playing around with near DC (20 kHz) for fun and profit
Offline ultranalog
    • It's only audio
« Reply #442 on: April 27, 2020, 11:19:39 pm »
I found an old D-link USB network adapter DUB-E100 and it works with this series of function generators out of the box.
https://www.bhphotovideo.com/c/product/403655-REG/D_Link_DUB_E100_DUB_E100_USB_2_0_10_100Mb.html
Offline Ruediger
« Reply #443 on: April 28, 2020, 06:02:49 am »
Additional to the changes in burst there is also a lower disruptive discharge voltage (+- 5V) in DG2000 series
Online tv84
  • Country: pt
« Reply #444 on: April 28, 2020, 08:43:52 am »
Does anyone want to try a simple script to extract the app from the DG?
If so, report the FW version and CRC32 of the extracted file.
Offline bulba99
« Reply #445 on: April 29, 2020, 10:15:34 am »
@tv84, how do you create a GEL file with sh scripts?
What tool does GEL file create?
Online tv84
  • Country: pt
« Reply #446 on: April 29, 2020, 11:42:41 am »
.GEL files are .tar files.
The following users thanked this post: ultranalog, bulba99
Offline Orycho
« Reply #447 on: April 29, 2020, 03:20:26 pm »
Hi there,
I write some scripts to control my pumped Rigol DG812 (Thanks to tv84). I finally decide to write a user interface to edit the arbitrary waveform for the function generator.
Here are some images of the software. The software needs NI-VISA runtime to communicate with the Rigol device.
If you are interested, you can go to my website (https://dpzhu.me/deltaz) to download and play with the software. For further development, you can leave the comments here or on my website.
Derek Z.
The following users thanked this post: thm_w, tv84, ultranalog, bitseeker, ch_scr, blubillcanada, Ruediger
Offline bulba99
« Reply #448 on: April 30, 2020, 09:45:52 am »
Thank you for confirmation.
I had a problem with tar implementation support under Windows.
It's OK now.  :)
Offline bulba99
« Reply #449 on: May 18, 2020, 01:33:34 pm »
I received DG811 today, with version FW 2.2.
NAND backup and NAND app. extract worked out correctly - thank you.
CRC32 for the extracted app is 5549a666.
Yours sincerely.
The following users thanked this post: tv84
