BTW, can someone explain me what's the difference between a DG992 and a DG2102? (to see if we should upgrade to DG2102)
In terms of datasheet:
- Built in HW LAN, as mentioned
- Burst characteristics -> carrier frequency: 2mHz to 30MHz vs 2mHz to 100MHz
Not sure if thats a typo or an actual limitation.
edit: can already set 100MHz sine in burst mode, so I don't believe there is a limitation.
