Hello Tv84,
First, thank you for this message.
Now, I must admit to doesn't be sure to understood all.
From your post #312 you explain that the magic command is now
":PROJ:MODIF DG992" for DG992 conversion.
(instead of previous ":PROJ:MODE DG992")
Then, you explain that it not work because there is an ECC signature.
So, it's not doable (easily ?).
You seem to explain that EEC (ECDSA) model string signature can be obtain by our-self,
but that is very obscure for me..
How i can obtain this, and what i do with ?
The other way would be to downgrade the firmware to previous one (00.01.08.00.01)
that allow the model change to work. Does this method has been tested successfully ?
I agree that if this work ok, that could be fine for me ! : )
Is there any feedback to others owners of DG811 with new firmware
that have done model change with success ?
Does Ashdash has been done this ?
Thank you for your efforts.
Best regards.
Frex
