Author Topic: New Rigol 16-bit function generators DG800/900 series  (Read 209532 times)
Offline Ashdash
Re: New Rigol 16-bit function generators DG800/900 series
« Reply #275 on: August 16, 2019, 06:11:01 am »
There are several adapters, also the "el-cheapo"-ones that work. Some of the cheapest ones aren't equipped with isolating transformers.
The funny thing is, some only get recognized by the DG800/900 after an active LAN cable is plugged in. After that, no problem (...only found this out after having bought three different ones -- altogether still a lot cheaper than the one Rigol offers...).
Cheers,
Thomas
I'm glad I read your post before going to the local computer shop.  I took the DG811 with me and would probably have rejected the adapter I bought if I hadn't known to plug onto an active cable.
And you also can't "Apply" the network settings if the cable is not connected.
This usb to lan adapter works fine. https://en.j5create.com/products/jue125
Offline Ashdash
« Reply #276 on: August 18, 2019, 07:19:46 pm »
Bump.
Has anyone with a recently purchased unit with firmware 00.01.09.00.00 been able to upgrade?  Care to share your experience?
Has anyone stumbled upon the root password?  I've tried the obvious ones.
It's not possible to downgrade to 00.01.08.00.01 which is available from rigolna.
Offline Ashdash
« Reply #277 on: August 19, 2019, 09:00:39 pm »
No luck logging in with "root" or "sshd".
I presume the passwd and shadow files are from a DGxxx firmware 00.01.08 or lower.  The shadow file shows that all accounts except root are disabled. (* in second field) Root has no password ("root::") but that has obviously changed.
I don't understand the significance of the ssh directory.  How does that help?  How do those keys help?
All and any help appreciated.
Offline thm_w
  • Non-expert
« Reply #278 on: August 19, 2019, 10:53:04 pm »
Try performing the downgrade by powering on and hitting the 'Help/Local' button to get to the low level tool.
Does it still block it?
edit: got an interesting screen with two options in Chinese, during boot, not sure what it said. Need to try to get that to show up again.
edit2: port 22 SSH, port 111 rpcbind, port 5555 freeciv.
« Last Edit: August 20, 2019, 12:57:14 am by thm_w »
Offline timber23
« Reply #279 on: August 19, 2019, 11:53:22 pm »
I have version 00.01.08.00.01 and I have no luck trying to log in with root and no password using SSH.
The ssh directory includes the authorized_keys. It is the public key of a PC which is allowed to log in, using its private key without password. Because the private key is unknown, the public key doesn't help.
Offline Ashdash
« Reply #280 on: August 19, 2019, 11:58:21 pm »
Did your instrument ship with 00.01.08.00.01?  Were you able to upgrade using the procedure earlier in the thread?
Offline timber23
« Reply #281 on: August 20, 2019, 12:05:11 am »
Yes. I did no update, since I received the device. Yes, I created an USB drive with the magic bytes and upgraded from DG811 to DG992.
This is how my "Info" screen looks like:
The following users thanked this post: Ashdash
Offline Ashdash
« Reply #282 on: August 20, 2019, 12:11:27 am »
Reading through the thread, some members seem to have trouble with the key, which they resolved, and also sending the ":PROJ:MODE DG912". which they resolved.
Can you share by what method your key was formatted and the package used to send the :PROJ command?
« Last Edit: August 20, 2019, 12:28:57 am by Ashdash »
Offline Ashdash
« Reply #283 on: August 20, 2019, 12:56:26 am »
I've tried several things with the 'Help/Local' key but I can't bring up low level screen.
If I put a usb drive with firmware 00.01.08.00.01 in the instrument with the Help screen showing, it loads and I get a dialog with 'Detects the upgrade file, upgrade? Touch 'OK' .  Waiting dialog box and then eventually returns to home screen. Upgrade dialog reappears. No downgrade.
EDIT.  Ok. Got to a low level screen in English. Keep pushing 'Help/Local' key when initial RIGOL appears onscreen, before progress bar appears.
No usb installed: 'Not found images...'    Instrument stopped, need to power off.
Usb installed:  'Upgrade from usb disk. Reading...'  wait and then  'ERROR: bad script!'   Instrument stopped.
« Last Edit: August 20, 2019, 02:31:46 am by Ashdash »
The following users thanked this post: thm_w, Relaxe
Offline Ashdash
« Reply #284 on: August 20, 2019, 08:19:34 am »
I'm going to declare that the hack is closed or changed in firmware version 00.01.09.00.00
At least until the clever people can get hold of the firmware and take a look at it.
It is not possible to downgrade to 00.01.08.00.01 which is known to work and available at rigolna.
I've tried a 2gb and 8gb usb sticks formatted FAT32 with the magic bytes at the correct location.  I've tried sending the the SCPI command by 2 different Windows packages and most recent  using Python under linux. Code snippet below.
>>> rigol = rm.open_resource('USB0::6833::1603::DG8Axxxxxxxxx::0::INSTR')  (xxxxxxxxx is serial no.)
>>> rigol.write(':DISP:BRIG 1')
(28, <StatusCode.success: 0>)
>>> rigol.write(':DISP:BRIG 100')
Insert key, waiting dialogue appears, wait
>>> rigol.write(':PROJ:MODE DG992')
(32, <StatusCode.success: 0>)
Power off, remove key, power up.
The 2 DISP strings are just sent to confirm the DG811 is receiving commands by dimming then brightening the display. Then insert key, and after waiting for dialogue box to disappear, send PROJ command.  Then power down and up.
Unfortunately, no upgrade.
Happy to help from here on.
« Last Edit: August 20, 2019, 08:24:43 am by Ashdash »
The following users thanked this post: Powernun
Offline tv84
  • Country: pt
« Reply #285 on: August 20, 2019, 08:40:45 am »
Root password is:
root:$6$KRD.PxZVpASx$V15pbKoUrwRvuPgiX8hegJD9uD3NbLllV6NDiH/A48Es4z9.pc40LGilqSEJifwwxwDKt1rn7yyW//Npp6Oi90:10933:0:99999:7:::
Anyone can break it?
« Last Edit: August 21, 2019, 01:29:51 pm by tv84 »
Offline thm_w
  • Non-expert
« Reply #286 on: August 20, 2019, 10:30:39 pm »
SSH version info:
ssh dropbear_2016.74 kippo honeypot
https://www.cvedetails.com/vulnerability-list/vendor_id-15806/product_id-33536/version_id-214300/Dropbear-Ssh-Project-Dropbear-Ssh-2016.74.html
I'm not sure how hard it is to exploit this vulnerability?
'root' is an SSH user, but 'sshd' is not showing as an accessible user. 'Rigol201' was the MSO5000 root password but thats not working here.
Offline thm_w
  • Non-expert
« Reply #287 on: August 20, 2019, 11:42:09 pm »
Dialogue box,"Detects the upgrade file, upgrade?" OK.
Rotating wait graphic, which stops and a relay click from the DG811, then after a further short delay waiting dialogue box disappears.  No apparent change in status.  No upgrade after power cycle.
Edit: Just tried to ssh with root. Still no access.
Did you try the GEL then SSH without a power cycle? I'm assuming here the GEL is making a temporary modification.
Offline Ashdash
« Reply #288 on: August 21, 2019, 01:04:41 am »
It seems we need to get down and dirty with the ssh thing. I'll try some GEL packs in the coming days.
Ashdash, try this GEL.
I'm new at this.  I'd don't see any option to attach files to a private message and how do you move files about over the 5k limit?
Offline tv84
  • Country: pt
« Reply #289 on: August 21, 2019, 10:06:14 am »
From analysis of the v00.01.09.00.00 app, I can confirm that the new FW version changes the previous method of changing Model.
The USB signature (sardinha.bin) is now placed in the last reserved sector of the USB disk and is XXTEA encrypted.
So, for those who have v00.01.09.00.00, you can write the file DG800_sardinha_v2.bin in the last reserved sector of a USB disk and use the usual SCPI command, as explained previously. Preferably disks with size smaller than 2GB!!
Here's also a small .GEL so that everyone can backup their NAND.  (It takes some minutes to run since it is 512 MBytes long.)
EDIT: Although this method with v2 would work, Rigol also disabled the :PROJ:MODE command in v00.01.09.00.00. So, now, a new command :PROJ:MODF must be used to change Model and this one doesn't use the same sector verification method.
« Last Edit: November 23, 2019, 01:29:34 pm by tv84 »
The following users thanked this post: thm_w, ogden, bulba99, lexaiden
Offline Ashdash
« Reply #290 on: August 22, 2019, 08:31:17 am »
Thanks again for your help.  The backup GEL worked fine.
But I still can't upgrade.
I have used python to send the SCPI string, doing the display test first.
Just to clarify where the sector should be written:
fsck.fat 4.1 (2017-01-24)
Checking we can access the last sector of the filesystem
Boot sector contents:
System ID "mkfs.fat"
Media byte 0xf8 (hard disk)
       512 bytes per logical sector
      4096 bytes per cluster
        32 reserved sectors
First FAT starts at byte 16384 (sector 32)
         2 FATs, 32 bit entries
   1921024 bytes per FAT (= 3752 sectors)
Root directory start at cluster 2 (arbitrary size)
Data area starts at byte 3858432 (sector 7536)
    480082 data clusters (1966415872 bytes)
62 sectors/track, 61 heads
      2048 hidden sectors
   3848192 sectors total
Checking for unused clusters.
Checking free cluster summary.
32 reserved sectors so I did dd if=/home/xxxx/Downloads/DG800/DG800_sardinha_v2.bin of=/dev/sdb1 bs=512 seek=31
No luck.
I thought maybe it should be before the data sector so then tried dd if=/home/xxxx/Downloads/DG800/DG800_sardinha_v2.bin of=/dev/sdb1 bs=512 seek=7535
No luck
 And I have tried also with an 8GB usb drive adjusting the seek to the appropriate values.
Any suggestions?
Offline Ashdash
« Reply #291 on: August 22, 2019, 12:48:54 pm »
For reserved sectors access, you must use sdb not sdb1. Sdb1 is the logical volume.
Reformatted drive and put a fat32 file system on it again.
Snippet from fdisk.
Using default response p.
Partition number (1-4, default 1):
First sector (2048-3850239, default 2048):
Last sector, +/-sectors or +/-size{K,M,G,T,P} (2048-3850239, default 3850239):
Then dd if=/home/xxxx/Downloads/DG800/DG800_sardinha_v2.bin of=/dev/sdb bs=512 seek=2047
And I've inspected the disk and confirmed "DG800_sardinha_v2" is written immediately in front of the logical volume stuff.
I tried the upgrade procedure again but still no luck.  But is "DG800_sardinha_v2" in the correct location now?
Offline tv84
  • Country: pt
« Reply #292 on: August 22, 2019, 12:53:57 pm »
Use fat16.
Offline Ashdash
« Reply #293 on: August 22, 2019, 01:05:10 pm »
Use fat16.
Same result.  No upgrade. The disk sectors don't look any different with fat16 (type 6 in fdisk).  2048 is the default and lowest value for the first sector.
Edit.  Just spotted a type 4  FAT16 <32M  in the fdisk types.  I'll try that.
Edit. Same result unfortunately.  Sectoring looks the same. Lowest sector for partition 2048.
« Last Edit: August 22, 2019, 01:14:03 pm by Ashdash »
Offline Frex
« Reply #294 on: September 03, 2019, 04:10:30 am »
Hi all,
I'm not sure so, as i understand the  DG800 hack is not possible anymore with new firmware ( 00.01.09.00.00)
as Ashdash latest attempts ? Somebody could confirm this or not ?
Regards.
Frex
Offline Frex
« Reply #295 on: September 03, 2019, 02:51:39 pm »
Ok, thank you for the answer  tv84.
So i will follow the thread with patience.  :D
Regards
Frex
Offline Alfons
« Reply #296 on: September 11, 2019, 01:03:46 pm »
Any News?:)
Offline Frex
« Reply #297 on: October 02, 2019, 03:19:19 pm »
I would love to get a DG800 with 100MHz sine output,
but the hack seem to be closed now so i'll need to found
something other to get a 100MHz output...
Not many choice  available in low price tag. :'(
Frex
Offline TurboTom
« Reply #298 on: October 02, 2019, 06:49:16 pm »
Amplitude accuracy of a hacked DG800 unit anyway is way beyond specs at frequencies above 70MHz. If we had the calibration instruction, we surely could convince a hacked unit to be accurate, but so far there's not even a firmware update (publicly) available -- not that it would be neccessary  ;). The recent 01.09.00.00 probably only had been released to close the hacking backdoors...
Anyway, I'm pretty sure the brillant code wizards attending here will find a way to get around that.  8)  :-+
Offline xzswq21
« Reply #299 on: October 16, 2019, 03:05:57 pm »
I want to buy a quality Signal generator especillay for Sine and Multisine signals to test my sensors. I want to publish the data with the IEEE.
I'm skeptical between Siglent SDG2042X and Rigol DG952. which one has more cleaner signal?
