Rigol MSO 5074 is currently being knocked out cheap with a few software bundles thrown in. Are these less buggy now, and are they hackable without a big headache.
Thanks Guy's
Search the forum there is a long thread on hacking. I think the hack is just as simple as plugging in a USB stick.
Most bugs would have been fixed, but all the scopes available out there have a bug list so you won't get around that, I have not found any show stoppers, and any concerns I have reported to support and they always answer and provide solutions. The other issue I discovered is that somethings are not bugs but result from persons not reading the manual.
Based on the chips used to get that extremely high sample rate, the noise floor is higher than the low sample rate models.
