Author Topic: NEW Next Gen 2 Series Tektronix Oscilloscope  (Read 72886 times)
0 Members and 14 Guests are viewing this topic.
Offline EEVblogTopic starter
Re: NEW Next Gen Tektronix Scope
« Reply #150 on: May 24, 2022, 01:04:53 am »
Are all of the front panel buttons capacitive touch so they only require a light tap, and not some horrible membrane buttons?
Membrane.
You wouldn't want cap touch when hand holding it, you could quite easily accidently activate them.
The following users thanked this post: gslick, JPortici
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #151 on: May 24, 2022, 01:11:19 am »
Display
• 10.1-inch TFT color
• WXGA (1280 x 800) resolution
• Capacitive (multi-touch) touchscreen
Bandwidth
70 MHz, 100 MHz, 200 MHz, 350 MHz, and 500 MHz
Sample rate
• 2.5 GS/s Half channels
• 1.25 GS/s All channels
Record length
10 M points per channel
Vertical resolution
• 8 bits ADC
• Up to 16 bits in high-resolution mode
I'll keep my TDS784D for now...
4 channel, 1GHz bandwidth, 4GS/s sample rate and 8M sample memory depth, all for less than $500 on the used market.
Sure it only has a 7" 640x480 colour CRT screen, but it has a floppy drive!  :-DD
( /facetious mode :P )
Membrane.
Like a cheap Chinese IR remote control? I hope they make them feel nice and clicky..
« Reply #152 on: May 24, 2022, 01:14:40 am »
It's not a HP calculator.
Offline Caliaxy
« Reply #153 on: May 24, 2022, 02:39:20 am »
Literally the first thing I tested in my unboxing video, it doesn't slide no matter how hard you push.
Unlike my Siglent SDS1104X-E…
Is it heavy? What’s the case made of?
Offline gslick
« Reply #154 on: May 24, 2022, 04:01:39 am »
Here's a bigger picture I pulled off the datasheet.
12MB 2 Series MSO Datasheet PDF is too large to attach. Grab a copy here:
https://www.farnell.com/datasheets/3723180.pdf
The following users thanked this post: edavid, trophosphere, tv84, gamalot
« Reply #155 on: May 24, 2022, 04:15:39 am »
The following users thanked this post: pcprogrammer
« Reply #156 on: May 24, 2022, 06:42:33 am »
To quote mighty boosh “elements of the past and future combined to make something not as good as either”
I reserve further judgement for the review but that looks like it’s really expensive and really easy to drop. I hope they sell TekCare with it and you can take it to Tek Store to get it repaired the same day.
Offline Someone
    • send complaints here
« Reply #157 on: May 24, 2022, 07:43:03 am »
Oh, how out of date can they get:
Digital pattern generator (optional)
Serial protocol triggering and analysis (optional)
Digital voltmeter and frequency counter (optional)
Digital channels (optional)
Arbitrary function generator (optional)
Battery pack (optional)
Fair enough on those last two, but not really trying to compete with the opposition.
already guessed by Fungus:
External power supply
and the pain in my side:
"One-year software maintenance that provides access to new firmware releases with updates"
"Maintenance for software: Maintenance license offers access to any software updates within the active period"
no firmware for you!
The following users thanked this post: 2N3055, bd139
« Reply #158 on: May 24, 2022, 08:19:49 am »
Their entire scope business is built around this model. Absolutely no surprises there at all. All of their major competitors like Keysight, R&S, and Lecroy do the same thing.
It's smart not to get into a race to the bottom when you are a top shelf player. You can always have specials bundling options.
« Last Edit: May 24, 2022, 08:23:06 am by EEVblog »
The following users thanked this post: E-Design
Online tggzzz
« Reply #159 on: May 24, 2022, 08:27:23 am »
Membrane.
So the screen is a membrane screen, not a touch screen?
Online JPortici
« Reply #160 on: May 24, 2022, 08:59:56 am »
I don't like the "Will be available in the future" options, or at least i don't get good vibes from that
I laugh at "TekCloud"
I hoped for isolated channels option because i actually like this form factor, in my mind i can see a lot of them in factory lines or workshop benches, either rack mounted or on VESA stand. Much more than the other "handheld" which are just really bulky (or with rather small screens) and usually with idiotic interfaces (RS scoperider comes to mind.. when i have the pleasure of using one i always get confused and press the wrong buttons) - and no, tautech i haven't had a chance to test the new siglent handhelds yet -
I am eager to look at the teardown video, i want to see how little space was left so that they couldn't add the optic fibre transceivers, or integrate a (smallish) battery beacuse the battery pack addon is... eh :D
overall i am impressed from tek, it looks really well done on paper.
Hope this will start a new wave of tablet scopes
Hope the other things (cloud, updates on subscription) don't catch on, but it may be too late already
« Reply #161 on: May 24, 2022, 09:30:50 am »
I like the design concept as it covers a lot of use cases....portable, battery powered, Toughbook type bumper protection when needed, VESA mount, tablet or bench use.
The remote PSU keeps size and weight down however fully powered for portable use with 2 Li-ion's bumps her up to a fairly hefty 8lbs which would be difficult to manage in one hand.
One glaring thing is the recessed BNC's which might indicate only proprietary BNC connectors can be used which will be a big howling  :--
Omissions from the datasheet are FFT pts ?  :-//
Std 1 yr warranty =  :--
Digital input channels (optional, available in future) < WTF is this future bit ? Out to customers for MSO development and feedback before we enable it ?
Anyways, looking forward to Dave putting it through its paces.  :popcorn:
Online 2N3055
  • Country: hr
« Reply #162 on: May 24, 2022, 09:38:13 am »
Well, in last 3000G series Keysight gives away basic protocols trigger decode...Also in 1000 series...
So some do realize that ship has sailed...
It looks fancy..
There are many features from their 3 series, large touch screen... I don't see it as a a handheld tablet type, it is too big for that, and battery dock is huge. I think this is more like office mobility thing, you can carry it around  the office without looking for socket... By looking at featureset, it looks designed to target R&S RTB2000 series customers.. Wonder what the price will be.
All in all it seems like Tek is finally refreshing their range.. How successful it will be? We'll see..
« Last Edit: May 24, 2022, 09:48:27 am by 2N3055 »
Online Fungus
« Reply #163 on: May 24, 2022, 09:45:28 am »
Sales reps can also use it to sweeten deals: "You buy 100 of them and I'll throw in the digital voltmeters for free..."
« Reply #164 on: May 24, 2022, 09:47:29 am »
They have to because they are still milking a 12 year old ASIC with limited memory. Much harder to compete these days.
The following users thanked this post: mnementh, 2N3055, bd139, ch_scr
« Reply #165 on: May 24, 2022, 09:52:39 am »
That's the big selling point, different use cases. They have executed it very well.
Not for everyone, as usual, but it's pretty killer for those that need it.
Nope, normal probes and cables are fine.
at present it does not have it, so I won't be able to test that.
« Reply #166 on: May 24, 2022, 09:55:41 am »
and no, tautech i haven't had a chance to test the new Siglent handhelds yet -
We'll have a demo unit coming in our next order but it's a month or 2 away yet then after a quick curious fiddle with it send it on down to Defpom for a review.....if you can wait that long.
« Reply #167 on: May 24, 2022, 09:59:33 am »
Screen is capacitive touch. Buttons are membrane.
« Reply #168 on: May 24, 2022, 10:02:21 am »
OK ordinary BNC's work.  :phew:
Do you have a SPL2016 in the lab Dave as it appears the Tek P6316 MSO probe is almost identical to the SPL2016 Siglent use. If we look at the digital socket on the RHS it looks the same shape and size for the PCIE connector Siglent, LeCroy, some Rigol and existing Tek models use.
« Reply #169 on: May 24, 2022, 10:06:40 am »
You'll see in the datasheet the VNC capability. I was playing with it today and it's very nice  :-+
Online JPortici
« Reply #170 on: May 24, 2022, 10:07:40 am »
Nah, i'll probably go say hi to the boys at one of the next faires and have a play there
Online tggzzz
« Reply #171 on: May 24, 2022, 10:10:18 am »
Yup, which begs the question as to how valid this point is :"You wouldn't want cap touch when hand holding it, you could quite easily accidently activate them."
I'm unconvinced of the widescale benefit of it being handheld: one hand to hold it, one hand to hold the probe in place, one had to control it. Niche cases, yes, but not for most purposes.
The VESA mount on a moveable support looks more practical, but extended regular use can lead to upper-limb disorders. (Light pens - remember those - tended to lead to arm/shoulder problems, and trackballs to thumb problems)
« Reply #172 on: May 24, 2022, 10:13:58 am »
If you had capacitive front panel buttons as suggested it would be a complete PIA if you hand hold or grab the side and move it around.
The cap touch screen can be turned off if needed, button on the front for that.
You generally wouldn't hand hold it, you'd take it with you somewhere and place it down. Being able to move your scope anywhere without dicking around with power, or simply disconnecting from the mains to prevent common mode noise pickup can be a big deal.
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #173 on: May 24, 2022, 10:22:38 am »
Totally unacceptable, especially in a new product that will have firmware issues that need fixing. I assume at least the first year will be included ?
Day Job: Mostly LEDs
« Reply #174 on: May 24, 2022, 10:27:03 am »
They're taking on the cheap Android tablet software model but charging iPad prices...
