Author Topic: NEW Next Gen 2 Series Tektronix Oscilloscope  (Read 76549 times)
Offline tggzzz
Re: NEW Next Gen Tektronix Scope
« Reply #25 on: May 18, 2022, 08:32:59 pm »
Doesn't "next gen" imply gesture or voice control using ML?
Can you imagine how annoying voice control would be in a lab with a bunch of other techs or a quite cubicle farm? Especially if you had several other scopes nearby.
I think it would be mostly offended at the language based on the labs I've worked in if it had that feature.
"Press the red tit" "No, this scope not that scope, you tit". But that would need gesture recognition too.
The following users thanked this post: 2N3055, bd139
Online EEVblogTopic starter
« Reply #26 on: May 19, 2022, 12:13:21 am »
It would be idiotic to make it so thin that it requires an external power supply. This isn't a TV set that needs to appeal to aesthetically minded housewives, it's a tool for professional engineers.
So why make it thin? It's obviously going to be less stable that way.
We'll see when it's released.  :popcorn:
Depends how you do it  :popcorn:
« Reply #27 on: May 19, 2022, 06:07:43 am »
When one rises, one must also fall. Guess which scope model this is going to replace...
Offline KrzysztofB
« Reply #28 on: May 19, 2022, 07:19:50 am »
Something 3-series-ish. Similar price range, maybe even cheaper. That's my bet.
Offline tggzzz
« Reply #29 on: May 19, 2022, 07:27:51 am »
Have any scopes been on special offer at Tek recently? That's usually a good hint.
Offline KrzysztofB
« Reply #30 on: May 19, 2022, 07:34:11 am »
There was very good deal on 3 Series MDO - expired 1 April 2022. You could save like 61%  |O
I'm pissed we missed that one, you could get almost fully loaded 350MHz for a price of 200MHz
Offline salviador
    • https://www.youtube.com/user/mancio92M
« Reply #31 on: May 19, 2022, 07:47:14 am »
I wonder if it will have a faster processor than their series 3 and 4. In my evaluations in 2019 (and later re-confirmed by their FAE earlier this year), the GUI of these two series still take quite a penalty with anything else put on screen, such as FFT, decoding, etc.
Thats still true. Even moving cursors with the knob is annoyingly slow at 4 Series. Really nice concept and functionality of the scope but somehow ruined by the lagging GUI and poor responsiveness.
Yes confirm, I have the 4 series, it is extremely slow. And remote web control is impossible to use
Offline KrzysztofB
« Reply #32 on: May 19, 2022, 07:58:46 am »
God damn. And I was planning to get 4 series for our lab as I was thinking my RTB2004 is laggy  |O
« Reply #33 on: May 19, 2022, 08:42:01 am »
I don't have a 4 series to comfirm. I presume the 3 series would be the same as the 4? I haven't really used any of the new 3/4/5/6 series.
What's the thing(s) that slow it down the most?
« Reply #34 on: May 19, 2022, 08:46:11 am »
Previous speculation:
https://www.eevblog.com/forum/testgear/new-tektronix-3-series-mdo/msg2570811/#msg2570811
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #35 on: May 19, 2022, 09:01:39 am »
In my evaluation, using simple measurements already had a palpable penalty, but still quite workable. Adding decoding or any processing like FFT (I don't recall if I tested simple math) brought such a drag to responsiveness that it severely handicapped usability. Think of a PC with mechanical drive and low memory, where the intense disk swap makes mundane actions such as accessing a menu or closing a window to take several seconds to react to the mouse click while the operation itself executes in a somewhat jagged slow motion.
I think they created the 6 series and started chopping off memory and processor power to create the product segmentation. In my experience they either did not test well their products, did not listen to feedback (common in product dev) or had a bunch of yes men in the room that thought the Tek brand would carry such flaws.
A lost opportunity indeed.
« Last Edit: May 19, 2022, 09:03:15 am by rsjsouza »
Offline Domitronic
« Reply #36 on: May 19, 2022, 09:27:14 am »
Afaik 5 and 6 series have different processors. For those a Windows option is also available while its not for 3 and 4.
I guess for 3 and 4 some older hardware is reused which is not really capable for todays expectations to a GUI.
Series 3 had a special offer for more than a year. You could get the MDO34 with 350MHz and almost all options for 5-6k€ plus tax. But thats not available anymore.
« Last Edit: May 19, 2022, 10:21:36 am by Domitronic »
The following users thanked this post: rsjsouza
Offline salviador
« Reply #37 on: May 19, 2022, 09:39:56 am »
Tek 4 has a cpu "AM5728 Sitara"
« Last Edit: May 19, 2022, 09:45:01 am by salviador »
The following users thanked this post: rsjsouza, bd139
Offline rsjsouza
  • Eternally curious
« Reply #38 on: May 19, 2022, 10:37:49 am »
Interesting. Indeed I had forgotten this difference, which was well advertised at the time.
The AM5728 is a reasonably capable multicore processor that runs Linux but it is limited to 2GB of RAM, which might explain the delays (disk swapping perhaps).
Offline salviador
« Reply #39 on: May 19, 2022, 11:09:29 am »
I don't think the problem is the RAM
I did a test, when the oscilloscope is running I have the CPU that runs at 98% and heats up to 80 °
I run the "top" command from the terminal
« Reply #40 on: May 19, 2022, 11:13:49 am »
Ah the problem be software engineers then. As always  :-DD
Offline rsjsouza
  • Eternally curious
« Reply #41 on: May 19, 2022, 12:31:13 pm »
The neverending rivalry... :-DD
« Reply #42 on: May 19, 2022, 02:43:15 pm »
It's pretty slick ;)
Online Fungus
« Reply #43 on: May 19, 2022, 06:34:39 pm »
Let's see how "next gen" it is compared to...
If it can't browse EEVBLOG forums then I'm not convinced.  :popcorn:
« Last Edit: May 19, 2022, 06:39:28 pm by Fungus »
Offline Stranger_danger
« Reply #44 on: May 19, 2022, 06:46:43 pm »
it has batteries. think of it as a low bandwidth hand held scope.
« Last Edit: May 19, 2022, 06:51:08 pm by Stranger_danger »
« Reply #45 on: May 19, 2022, 11:56:53 pm »
That music  |O
Real scopes don't have web browsers.
« Reply #46 on: May 20, 2022, 12:23:40 am »
It's pretty schmick.
The following users thanked this post: SeanB, 2N3055, bd139, ch_scr
Offline w2aew
    • My YouTube Channel
« Reply #47 on: May 20, 2022, 01:06:54 am »
LOL!
All I can say about this new product is...   Xx xx xxx xx xxx xxxxxxx xxx xxxxxxxx xxxx x'xx xxxx xx x xxxx xxxx.
(Sorry, all comments are redacted until June 7/8)
FAE for Tektronix
Offline Jeff eelcr
« Reply #48 on: May 20, 2022, 02:22:19 am »
If its too light just add lead weight to the base.
Jeff
Online Fungus
« Reply #49 on: May 20, 2022, 03:01:09 am »
You can read datasheets on it.
