Author Topic: New low-cost ($170) 100MHz Differential scope probe from Micsig  (Read 87778 times)
Offline tautech
Re: New low-cost ($170) 100MHz Differential scope probe from Micsig
« Reply #25 on: July 13, 2017, 09:57:13 am »
Kudos for the 5V power input, as it can be powered by ordinary cellphone's power bank.
More so for the USB jack on the side so they can be daisy chained.  :-+
Someone was using their gray matter.  :clap:
not enough grey matter. that thing need mains supply or power bank around in order to work. i wish someone has enough wisdom of using 2 rechargable li-on stacked inside (preferably 18650 size hence easily replacable) 7.2V with charging circuitry (from 5V USB) that doesnt block operation during charging (ie charging while probing)...
Well until somebody does a teardown we'll never know.
DC-DC convertor ..................
Offline simone.pignatti
« Reply #26 on: July 13, 2017, 10:44:01 am »
In case of interest, we have the combo kit (2x) at Euro 185 + VAT
Technical Support
Offline TheAmmoniacal
  • Country: no
« Reply #27 on: July 13, 2017, 10:53:17 am »
What do you mean by a combo-kit? Two units?
« Reply #28 on: July 13, 2017, 10:53:59 am »
Yes
Technical Support
  • Country: no
« Reply #29 on: July 13, 2017, 11:00:59 am »
If I wasn't on vacation at the moment I'd likely go for it.. Do you want VAT too?
« Reply #30 on: July 13, 2017, 11:02:53 am »
Better to stay in holiday ;)
About VAT, yes it is mandatory within EU but not for registered company.
Technical Support
Offline Hydron
« Reply #31 on: July 13, 2017, 11:10:32 am »
I am very interested, can you PM me the details of how to place an order for the combo kit?
Only thing that stopped me already ordering one is that nobody seems to have testedd one to check if it does what Micsig says (i.e. noise level, bandwidth etc). Have you tried one of these probes out yourself?
  • Country: no
« Reply #32 on: July 13, 2017, 11:12:17 am »
That's why we need a review and a teardown, but mike is busy.
What about a side-by-side comparison with Dave's diff probe? Drawbacks of 50X/500X vs. 10X/100X.
« Last Edit: July 13, 2017, 11:16:38 am by TheAmmoniacal »
« Reply #33 on: July 13, 2017, 11:16:16 am »
message sent
Technical Support
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #34 on: July 13, 2017, 11:54:43 am »
from the spec, the power supply is DC 5V and USB, no mentioning of battery size or unplugged operating hour, no power switch etc. i have suspicion there is no battery in there.
« Reply #35 on: July 13, 2017, 12:01:29 pm »
Correct, no battery. the pic shows what we have
Technical Support
Offline Jeroen13
« Reply #36 on: July 13, 2017, 01:04:20 pm »
Do you have a webshop or just 2 probe spare ?
« Reply #37 on: July 13, 2017, 01:06:12 pm »
we have a webshop  :-+
Technical Support
Offline Jeroen13
« Reply #38 on: July 13, 2017, 01:21:32 pm »
Just ordered 2 pieces, will try to compare it to Tek THDP0200 and Tek IsoVu TIVM at work when I have them.
« Last Edit: July 13, 2017, 01:24:46 pm by Jeroen13 »
« Reply #39 on: July 13, 2017, 01:22:19 pm »
thanks, shipping out today
Technical Support
Online JPortici
« Reply #40 on: July 13, 2017, 02:15:56 pm »
Hi simone, for how long are you going to do this promotion?
« Reply #41 on: July 13, 2017, 02:17:10 pm »
ciao, for sure till September '17
Technical Support
The following users thanked this post: JPortici
Offline 2N3055
  • Country: hr
« Reply #42 on: July 13, 2017, 02:18:46 pm »
With a 500X probe, noise is potentially problematic...
Does anybody know what is noise spec ..?
« Reply #43 on: July 13, 2017, 02:22:07 pm »
?40mVrms (50X)
?230 mVrms (500X)
Technical Support
Offline Hydron
« Reply #44 on: July 13, 2017, 02:25:16 pm »
Input referred noise spec:
?40mVrms (50X)
?230 mVrms (500X)
An example of pk-pk noise (measured by Micsig, compared with Tek P5200A) can be seen on the aliexpress listing linked in the OP.
If the noise spec (and other specifications) are true, these could be a really good deal if the somewhat low sensitivity (50x) is OK for the intended application.
edit: see http://www.micsig.com/UploadFiles/file/High%20Voltage%20differential%20probe.pdf
I note the oddity of 75R output impedance though - not an issue if it's driving 1Mohm input, but unusual and annoying if you want to drive 50R! Is this really the impedance, or is it a typo?
« Last Edit: July 13, 2017, 02:28:14 pm by Hydron »
Offline nidlaX
« Reply #45 on: July 13, 2017, 02:49:25 pm »
?40mVrms (50X)
?230 mVrms (500X)
It is actually 75 Ohms according to their engineering department. I told them it's a strange choice, not sure why they made this decision. Keep this in mind if you decide to use a BNC cable extension.
By the way, if anyone finds any typos in or needs clarifications regarding anything in the user manual, let me know.
Offline DK-1
« Reply #46 on: July 13, 2017, 07:47:54 pm »
I bought 2 just now!
For this price i was too much curious to try it, when arrived i will tell something
Online nctnico
« Reply #47 on: July 13, 2017, 07:54:53 pm »
Is there any CAT rating on this differential probe? Without it I wouldn't want to use it on anything mains powered.
Offline alm
« Reply #48 on: July 13, 2017, 09:05:29 pm »
It does not appear to be silkscreened on the case or printed in the datasheet, so I would assume not. Probably no independent testing either. So safety for mains voltages is suspect.
  • Country: my
« Reply #49 on: July 13, 2017, 11:29:18 pm »
?40mVrms (50X)
?230 mVrms (500X)
the output coax cable probably 75ohm.just add 75ohm terminator at scope end to get nonoddities 100/1000x figure.
