Quote from: tautech on July 13, 2017, 08:19:16 amQuote from: BravoV on July 13, 2017, 08:12:44 amKudos for the 5V power input, as it can be powered by ordinary cellphone's power bank.More so for the USB jack on the side so they can be daisy chained. Someone was using their gray matter. not enough grey matter. that thing need mains supply or power bank around in order to work. i wish someone has enough wisdom of using 2 rechargable li-on stacked inside (preferably 18650 size hence easily replacable) 7.2V with charging circuitry (from 5V USB) that doesnt block operation during charging (ie charging while probing)...
In case of interest, we have the combo kit (2x) at Euro 185 + VAT
Quote from: simone.pignatti on July 13, 2017, 10:44:01 amIn case of interest, we have the combo kit (2x) at Euro 185 + VATI am very interested, can you PM me the details of how to place an order for the combo kit?Only thing that stopped me already ordering one is that nobody seems to have testedd one to check if it does what Micsig says (i.e. noise level, bandwidth etc). Have you tried one of these probes out yourself?
Quote from: Mechatrommer on July 13, 2017, 09:48:09 amQuote from: tautech on July 13, 2017, 08:19:16 amQuote from: BravoV on July 13, 2017, 08:12:44 amKudos for the 5V power input, as it can be powered by ordinary cellphone's power bank.More so for the USB jack on the side so they can be daisy chained. Someone was using their gray matter. not enough grey matter. that thing need mains supply or power bank around in order to work. i wish someone has enough wisdom of using 2 rechargable li-on stacked inside (preferably 18650 size hence easily replacable) 7.2V with charging circuitry (from 5V USB) that doesnt block operation during charging (ie charging while probing)...Well until somebody does a teardown we'll never know.DC-DC convertor ..................
Input referred noise spec:?40mVrms (50X)?230 mVrms (500X)An example of pk-pk noise (measured by Micsig, compared with Tek P5200A) can be seen on the aliexpress listing linked in the OP.If the noise spec (and other specifications) are true, these could be a really good deal if the somewhat low sensitivity (50x) is OK for the intended application.edit: see http://www.micsig.com/UploadFiles/file/High%20Voltage%20differential%20probe.pdfI note the oddity of 75R output impedance though - not an issue if it's driving 1Mohm input, but unusual and annoying if you want to drive 50R! Is this really the impedance, or is it a typo?
Quote from: Hydron on July 13, 2017, 02:25:16 pmInput referred noise spec:?40mVrms (50X)?230 mVrms (500X)An example of pk-pk noise (measured by Micsig, compared with Tek P5200A) can be seen on the aliexpress listing linked in the OP.If the noise spec (and other specifications) are true, these could be a really good deal if the somewhat low sensitivity (50x) is OK for the intended application.edit: see http://www.micsig.com/UploadFiles/file/High%20Voltage%20differential%20probe.pdfI note the oddity of 75R output impedance though - not an issue if it's driving 1Mohm input, but unusual and annoying if you want to drive 50R! Is this really the impedance, or is it a typo?It is actually 75 Ohms according to their engineering department. I told them it's a strange choice, not sure why they made this decision. Keep this in mind if you decide to use a BNC cable extension.By the way, if anyone finds any typos in or needs clarifications regarding anything in the user manual, let me know.
