I just noticed that Lidl have a couple of meters coming up on Easter Monday. Both look aimed more at the electrical market. One is a pen type and the other a clamp meter (AC current only). They've upped the odds on these two with Cat III 600V ratings, both are GS marked and TUV certified so there's good reason to believe these. Not bad for £12.99 UK.
https://www.lidl.co.uk/en/p/diy-tools/parkside-digital-clamp-meter-or-pen-multimeter/p41447The pen meter certainly looks the part, with tool accessible batteries, decent finger guard and GS38 shrouded probes. With the enhanced ratings, it might make a useful partner for a average low Cat rated DMM for mains / higher voltage use.
The clamp meter probably fairs badly against the UT210E as it only has AC clamp ranges, but there again, it does have a 600A range without EEPROM mods and is half the price.
There's a very brief teardown of the pen multimeter in the YouTube video below - 13 mins in. Melf attenuator resistors, Fusible through hole resistor, single PTC and plenty of clamp diodes in evidence. I'm not keen on having shared sockets for the uA and mA ranges on a Cat III meter, but at least it does have a proper 250mA 600V ceramic fuse. At least there are no higher Amps ranges, which ought to reduce the drama of accidental current range selection. The IC is glob top.
P.S. They have their 20V 2Ah and 4Ah batteries in again on the same day, together with a spare charger sold separately for once (it's usually bundled with a 2Ah battery).
