Narrow runts are what you find so hard to find? Here is an Agilent 3024A picking up a <500ps runt that occurs 1 in every 10,000,000 transitions, thats the screen capture result from seeing 1 runt added to the persistence. It stands out as we say in Australia "like dogs balls".
Yeah, on a ~3.6MHz signal
Well done for again completely missing the point I now made several times that missing stuff on persistence is more likely on high frequency signals.
You've never explained how you look for an unknown signal characteristic with triggers, please do provide some examples, we'd be interested to have some other ways of doing it for those scopes that don't have the fast realtime update rates.
It's simple, really, instead of telling the scope to look for a specific glitch, runt or whatever you pretty much tell the scope how the signal should look like and let the scope show you any occurrences where it deviates from that ideal.
The most simple and common way to do this is mask testing, which is also available in many entry level scopes. Mask testing works fine for truly repetitive signals, and on a somewhat modern highend scope it just doesn't tell me when a deviation appears but also what it is. The scope can build up a histogram with time stamps of each violation, take measurements or create a screenshot of each occurrence.
For non-repetitive signals it's a bit more complicated, and depends on what kind of wanted signals you're looking at. If it's a standardized protocol (i.e. USB2) then the easiest way on a LeCroy scope is to use the SDA package to verify signal integrity. It can pretty much work like mask test just for non-repetitive signals (although it can do a lot more). If there's a violation (runt, glitch, excessive jitter, whatever) then the scope will record and report it. SDA also works with non-standard signals although the setup is a bit more complicated there.
If your scope doesn't have the SDA option then LeCroy still offers WaveScan/TriggerScan. WaveScan is standard with every of its mid-range and high-end scope with the exception of the WaveSurfer 400. WaveScan can 'learn' how the signal should be, search for any deviations and then do what you want it to do (record, analyze, alarm you).
Of course you could also use individual triggers (i.e exclusion triggers) to find specific glitches, but that often takes more time than just using the scope's toolset.
Since you have this fixation on the Keysight 6000 series
I compare against the DSOX6k because itit's in the same price and market segment as the scope on topic. Actually, price-wise I could as well add the DSOX4k to the list, but that compares even worse than the DSOX6k.
I know that you already suggested I should compare against a much more expensive Keysight scope as this will be better
You stick to it because it allows you to make these deliberately misleading comparisons,
No, I compare it because it's the same class (500Mhz to 4Ghz) and price range.
Keysight offer scopes with broadly comparable specifications to this Lecroy model, they are more expensive (20-30%) but share many characteristics. The Keysight X series are radically different and dont share the same characteristics, they arent a good comparison.
Why not? Because you don't like the outcome?
Fine, let's take the next step up, the Infiniium DSO9000A. They are actually great scopes, it's the first proper Infiniium (Windows scope) Agilent came up with, and it still sells very well. OK then, let's see:
http://literature.cdn.keysight.com/litweb/pdf/5990-3746EN.pdf?id=1705234[...]
Waveform update rate:
Segmented mode: Maximum up to 250,000 waveforms/sec
Real-Time mode: - Typical of 700 waveforms/sec with 1kpts memory
- Typical of 230 waveforms/sec with 100 kpts memory
- Typical of 130 waveforms/sec with 1 Mpts memory
As I said the waveform update rate isn't very important in these scopes, but it's notable that the DSO9ks waveform rate is much lower than the WR8k. In fact, it's even much lower than the 10 year old WaveRunner Xi I have here, which in segmented mode goes up to 1.25M wfms/s. LeCroy doesn't specify real-time update rates but a while ago I did some measurements on the WRXi and got around 380 wfms/s at 50ns/div with 500k memory. And that WRXi is still an original X-Stream architecture scope (PCI based). It had two successors before that new WR8k, the WRXi-A (first X-Stream II variant) came out at roughly the same time as the DSO9k, and provides higher real-time update rates than the WRXi. And the successor of of the WRXi-A (WR6zi) is even faster, noticably. Now, the WR6zi is replaced with the WR8k, and I find it hard to believe that this new scope wll be any slower than its predecessor (but then, there were cutbacks in memory size and the display, so who knows).
Not that this matters a lot, because as I said, unlike what you believe in this scope class waveform rates aren't of high importance.
Aside from that, the DSO9kA comes with more sample memory (20M/40M, optional 500M/1G) which is great, an inferior display (XGA 1024x768) which is not great, and a roughly comparable set of options and protocols, all at a roughly $17k+ starting price.
As noted by an intelligent poster:
I would be disappointed if a new product wasn't better than existing product in a similar price category, that's a natural technology progression, granted test equipment seems to have very long update/refresh cycles...compared to phones
New product to market achieves similar capabilities at lower cost than existing products, its nothing amazing or exciting.
True, but the thing is that the more expensive Keysight model (DSO9k) is already slower than the 10+yrs old pre-pre-predecessor of the scope on topic, which isn't exactly stellar. The DSO9k gets bonus points for being a better Infiniium (than its predecessors, which were all pretty poor), it has very decent sample memory (and a nice 1G option), plus it's supported by the 89600A/B VSA software which, if you do signal analysis, is great.
But back to the original topic, it means Keysight has nothing even close in the same price bracket which offers any similar bang for the buck.
That's the re-arm time, which is not the only factor determining the update rate. I'm pretty sure the InfiniiVision scopes don't reach higher waveform rates in segmented mode than in real-time mode due to their architecture, which for the DSOX6k would be ~450k wfms/s.
looks like Tek got it wrong (I guess they got confused because you can't select normal persistence mode in WaveStream which already is a persistence mode ), and maybe if they spent less time talking about the competition and invest more time building scopes that aren't old shit then maybe their market share wouldn't be in a constant decline and they wouldn't need to embarrass themselves by having to compare their scope with an older scope of a competitor
So Tek and Keysight are telling us lies, and we should believe your made up numbers that come with no backup.
http://cdn.teledynelecroy.com/files/appnotes/wrxi_note3.pdf(careful, that is really old!)
"WaveStream combines a rapid screen update rate with a persistence display to show a history of the waveshape variation"Made up, eh?
But if you prefer to use marketing BS as source be my guest.
Also, unlike Tek's DPO mode, WaveStream allows to use maths and measurements as on a normal acquisition.
Tek are highlighting how the Leycroy offerings do not compete some Tektronix products due to with their slow realtime update rates. But you continue to claim how amazingly fast the realtime speed of Lecroy scopes are despite everything saying they arent.
Tek is desperate because pretty much all their scopes except the DPO70kSX are shit. It's pretty embarassing when they have to use a LeCroy scope that came out in 2007(!) and which has already been replaced in 2009/2010 to their own product that came out in 2012. And as shown they couldn't even do this right without either lying or messing up.
Seriously, if you take Tek's marketing BS serious then more fool to you.
