This segmented / history is seriously broken. I thought we talk about 2.5us delay only between re-arm when using fast mode ?
Firmware 2.3
I try to capture this waveform in segments. I can expect about 21 segments.
Whole data at 20 and 50 ms, it´s always like this, not more not less.
First try with history, still running shows this:
Three segments ? seriously ?
No fast segmentation.
One cannot scroll, because its not stopped.
Now try with fast segmentation:
twelve segments, but look at the delay !
Another try:
seventeen segments. What is this thing doing for 43ms on segment -7 ?
Missing my frames !
It´s unusable.
I tried auto mode, which does of course not work at all, because it´s constantly filling history and loosing my data immediatly.
Then manual mode, see results above.
Also tried single with N=20, which shows exactly the same.
Also tried not sinx/x to no avail.
I think my unit is defective.
Or maby not, but disappointing nonetheless. It seems to only (!) work in single trigger and fast segmentation.
I mean this is bursts with 10ms distance, and it cannot write it to memory only in single and fast segmentation ?
Very poor performance R&S
More tests with Trigger to Aux Out show no more than 5ms / 200Hz whatever I configure.
I thought it´s the measurements, but no.
So basically R&S 50000 waveforms per second is 200.
