Hi Everyone,
The new RTB2000 FW should be out shortly - it has been released to the web team for posting. In the meantime, here are the release notes (as always, this may not capture everything, but should give a pretty thorough overview):
New Function of Firmware V02.101:
V02.101 Vertical zoom: Use the zoom tool from tool bar to draw a rectangle and zoom into.
V02.101 Quick Access: Pull out a menu item and drag onto the screen. Also use the tool in tool bar.
V02.101 Auto Scale in channel short menu.
See channel short menu (touch on channel segment in signal bar if channel switched on).
V02.101 Option RTB-K15:
History menu available. Touch on History item in main menu.
Analyze functions Overlay, Average and Envelope in segment player.
See menu 'History' item 'Show History'.
V02.101 Tool Menu History. See configuration tool bar.
Modifications of Firmware V02.101:
Increased segment numbers with 50ksample, 500ksample and 5Msample record length.
V02.101 FFT start frequency value limited to 0 Hz and stop frequency limited to sample rate / 2.
V02.101 Reduced channel segments in signal bar when channel off.
V02.101
Initial roll mode: Trace fills screen from left side to right side.
V02.101 Note on frequency limitation of the Meter in footer.
V02.101 Closing button in zoom mode added.
V02.101 Acquisition memory is set to maximum when roll mode on.
V02.101 Front panel firmware updated to version 01.011.
Battery management improved.
V02.101 Various improvements in GUI and languages.
Improvements of Firmware V02.101:
V02.101 Solved: Wrong calculation of counter threshold with clipped ADC data.
V02.101 Solved: Wrong displayed bus data with parallel or parallel-clocked bus if the horizontal
position during stop mode changed.
V02.101 Solved: Firmware blocker if I2C bus decoded and 'Display Settings' set to 'ASCII'.
V02.101 Solved: In acquisition average or high resolution mode only coarse cursor positioning with
horizontal cursors.
V02.101 Solved: Wrong date saved in CSV file if the acquisition not complete.
V02.101 Solved: Possible spike in waveform data with infinity persistence and manually device
operation.
V02.101 Solved: Trigger offset of 10ns with peak detect and 625MSa sample rate.
V02.101 Solved: Option RTB-K15:
After mask violation history player stops one segment to late.
History player overlays segment table with maximized waveform window.
V02.101 Solved: MTP function with Windows 10:
Windows prevents copying files to the instrument with file extensions unknown to Windows.
Known issues of Firmware V02.101:
V02.101 Connection via USB-TMC: Read function 'viReadSTB' does not answer.
-Rich
