Hi, just got my RTB2004 (100mhz & all decode option upgraded). I noticed that if you use I2C decoding, and disconnect the SDA, the scope hangs. This is reproducible by just using the demo included in the scope.
Just to make sure I did the right thing, here are the steps I did:
- Press "preset" (just to make sure all are in default)
- Under demo, protocols, run I2C
- Connect probes C1 and C2 to P0 and P1 respectively as instructed.
- Adjust trigger level to get proper trigger (scope then shows decoded output)
- After a few seconds (30 seconds or so) disconnect the C2 probe
Whole unit now "hangs". All buttons/presses unresponsive except the soft power button. Sometimes it won't hang right away but, if you reconnect and disconnect for few times (with natural contact bounce of the probe), it will hang.
Can anyone please test this to verify? Did I do something wrong? I mean, is it a natural tendency to hang if it's done?
Thanks.
