Author Topic: new killer scope in town - a true game changer from R&S - RTB2002 & RTB2004  (Read 890493 times)
Online mikeselectricstuff
    • Mike's Electric Stuff
Any clue about if they scheduled for releasing firmware update?
Rich was saying this month, and this was a fairly early reported issue, and acknowledged., so hopefully that will be fixed.
Day Job: Mostly LEDs
Offline Rich@RohdeScopesUSA
Still planned for May, but I'll get another update and let everyone know ASAP.
-Rich
The following users thanked this post: mtdoc
Offline Robaroni
  • Retired EE
    • Design Specialties
Thanks Rich,
Here's the link again for updates.
Rob
https://www.rohde-schwarz.com/firmware/rtb2000/
Offline ruairi
I just got mine on Tuesday and I'm really impressed, it's very well organized and I only had to reach for the manual once.
On the same day I also got some fantastic news that sets me up for some very expensive months ahead, I may have to go the eBay route.
Online Hydron
Just did a quick check with a 10 quid maplin wattmeter (0.1W resolution) for interest:
0.5W in standby (much lower than mike's number, possibly suspiciously low)
48.5W during acquisition, most channels and ethernet enabled, no USB device/host though
Measured ~0.6 power factor while running, almost 0 during standby.
If the 0.5W number is even vaguely accurate then I forgive having the soft power button
Offline mtdoc
Got mine 2 days ago.  I am blown away by how nice the screen and user interface is.  I'm finding the touch screen very convenient. No noticeable lag for me but I'm coming from a hacked Rigol DS 2072 (though I have played a bit with Keysight infinivision scopes).
I consider myself a middling hobbyiest though I did spend 10 years using analog oscilloscopes professionally from the mid 1980s to 1990s.    The Rigol was my first DSO and it's been a great scope but I've recently been finding the need for more channels . I had planned to spend about $1500 or so on a new 4 channel scope but when the package deal on this scope came along I could not resist (and I'm lucky enough to be at a place in my life where I can afford it). This is way more scope than I need right now but hopefully I'll grow into it.
The only issue I've had so far is getting the remote LAN connection to work on a Window's machine. I've tried both my Win 7 Laptop and the XP machine in my lab. An IP is assigned and the scope says a link is established but put the IP in a browser window and nada! I've tried all the usual things, turning off firewalls, different browsers, cables,  etc but nada.  Aargh - I despise Window's networking. |O  Any advice welcomed!
Ironically, my 10 year old Mac Laptop has no problem connecting.  I checked the rise time with my Tektronix DSO demo board that has a pulse with a rise time specified at < 200ps.  The scope shows a risetime that hovers around 1 ns which puts the BW at about 350MHz - the same ballpark as others have found.
Bottom line - I LOVE this scope. Now I need to up my game to take advantage of all it's features.
« Last Edit: May 18, 2017, 08:31:02 pm by mtdoc »
The following users thanked this post: vokars
I had no issues connecting under Win7 ( using Firefox)
Offline mtdoc
Thanks. I think the next step is to attach the scope to my wireless router and see if I can connect that way instead of direct scope to computer cabling.
My usual back asswards approach to Windows networking issues is to try different things until one works and then work back from that.  I wish I had enough networking skills to approach it more systematically.. ::)
Offline KE5FX
    • KE5FX.COM
If you hook it up directly to the PC, it will not get a DHCP address.  Connecting it to your router should fix that problem.
You can hook it up directly to the computer but you'll have to assign it an address, gateway, and subnet mask manually.  Much easier to attach it to your LAN's existing DHCP server like any other PC.
Offline mtdoc
OK thanks. That sort  of makes sense. In hindsight I should have tried that already ( I will when I get home).   But why does it work fine when directly connnected to my Mac laptop?  Doesn't a direct Windows box connection support DHCP?   It does appear to get assigned an IP address when directly connected to the Windows box (so I assumed DHCP was functioning).  Also it would be nice if the manual would spell that out..
« Last Edit: May 19, 2017, 12:57:53 am by mtdoc »
Offline KE5FX
    • KE5FX.COM
Couldn't say for sure.  In my experience Windows does not enable a DHCP server by default.
Offline Electro Fan
Hi mtdoc, Congrats on the new scope!  If you have the serial decoding (and the digital channels?) let us know how things compare to whatever you had (serial decoding?) on the DS2072.  Thx, EF
Offline mtdoc
Thanks and I will. But the truth is, I made very little use of the Rigol's serial decoding - in part due to the small screen and in part due to it only having 2 channels. I've mostly been using a cheap eBay logic analyzer or my Digilent Analog Discovery.  Now that I have a scope with a big screen and 4 channels (plus 16 logic channels oh my!) - I will definitely be decoding on the scope more.
Offline kaz911
After few delays etc :) I'm now also a RTB2004 owner - only got 59 minutes with it so far - but seems fine apart from a few issues here and there.
Now after kids are asleep I'll try to measure some microphones. hmm...
Offline casinada
No issues here connected to Windows 10 Pro using Google Chrome or Microsoft Edge.  :-+
I don't know if anybody mentioned that the probes are made by Texas:
http://www.hktexas.hk/en/pro_passive_probe.html
The model number seems to be : TX5430 or TX5130 (with metalic BNC)
http://images.100y.com.tw/pdf_file/59-TEXAS.pdf
The only difference seems to be that the RT-ZP03 doesn't come  with the BNC to probe tip adaptor and the colors of the identification tags for the probes.
http://www.hktexas.hk/en/pro_pa.html
Any comments on the probes?  :)
« Last Edit: May 19, 2017, 03:27:20 pm by casinada »
Offline agdr
    • agdr Audio
Only that they are not actually in Texas, see below (I'm in Texas).  8)
« Last Edit: May 19, 2017, 08:29:59 pm by agdr »
Offline casinada
Yes, Hong Kong Texas  :-DD
Online coppice
Yeah, they are about as honestly named as Paris, Texas, complete with its own Eiffel Tower.  :)
Online Hydron
Seems that LeCroy uses the same OEM for some of their probes, as I found out when their accessory bundle fit the R&S probes: https://www.eevblog.com/forum/testgear/new-killer-scope-a-true-game-changer-from-rs-rtb2002-rtb2004/msg1200931/#msg1200931
Offline 1design
Just got mine, looks good. I can't wait to get some spare time and integrate it into Matlab to add the VSA functionality :-+ :popcorn:
Not a 14 bit front end, but still, for low order modulations it should work pretty well with the fast ETH interface!
Online skench
Did Dave give up on a in depth review of this scope?
Offline JoHr
...  at least Dave could measure with it :-+
The law of conservation of bugs states that the total amount of  bugs of an isolated system remains constant. Bugs can neither be created nor destroyed; rather, they can be transformed from one form to another.
Offline Pinkus
Maybe he just waits for the first firmware update which -imho- would make sense.
Offline norks
There's an updated datasheet for the RTB out now, I compared it to the last one and there were 2 changes...
Added to compliance section:
"in line with EN 55011 class A, operation in
residential, commercial and business
areas or in small-size companies is not
covered; therefore the instrument may not
be operated in residential, commercial and
business areas or in small-size companies
unless additional measures are taken to
ensure that EN 55011 class B is complied
with."
(...so I guess that means it has the potential to cause interference in excess of that spec.)
UART decode spec changed: max bitrate officially reduced to 3 Mbps.   :-\
Offline Robaroni
  • Retired EE
with."
OK, what's EN 55011 class B?
