It does often seem to do more apparently intialising- type stuff when changing apparently minor things, like it's reinitialising everything on any change that might affect something rather than only changing what's needed - I think maybe this makes some things fell a little more clunky than they should.
A few more minutes playing uncovered this problem:
I was aware that early adopting will give me buggy firmware, but this is quite a substantial hardware issue. Let's see how annoying this will be when using it for real. R&S care to comment?
Also, I must admit I find it a bit amusing how Dave seems genuinely disappointed at first when Siglent doesn't seem to exhibit any tapping problems while the Rigol is "good old" even the second before showing the ridiculous scale of effect at the slightest of touches
How many people actually tap on a touchscren?
All scopes to it to some extent.
On my unit I also see ch1 being more sensitive, but no sensible-strength tap on the screen shows it at all.
Only "good old" because every man and his dog has one.
All the time.
All the time.I've never touched harder than is needed - maybe different people have different styles.
The problem with the R&S is that a big feature is the touch screen, and you can see at the end of the video how just tapping it causes a large scale signal impulse. And I was only at 2mV per division, not 1mV.
This. Dave seems to inadvertently trigger some action on any touchscreen device in pretty much every episode featuring one ("Bloody touchscreens!")I, on the other hand, hate fingerprints on non-touch screens and I'm sure I have stuff I used for years without ever putting my greasy fingers to its LCD. We had one colleague at work who was going absolutely ballistic when you touched his PC's screen.
It does seem to vary between units - maybe depends how tightly the screws near the front-end are tightened - I think mine had loctite on before i took it apart - have you had yours apart yet ?
Mine shows significant disturbance on ch1, and only slight on ch4 when tapping the top case with fingers.
Really don't see it being a problem.
Thanks R&S for letting me spend >2k$ on a scope that's broken by design! Luckily it was only 2k$ and not 8k$. I was aware that early adopting will give me buggy firmware, but this is quite a substantial hardware issue. Let's see how annoying this will be when using it for real. R&S care to comment?
