Author Topic: NEW 100MHz Keysight Scope Release on 1st March 2017  (Read 251045 times)
Offline bobaruni
Re: NEW 100MHz Keysight Scope Release on 1st March 2017
« Reply #275 on: February 17, 2017, 01:48:47 am »
Can Aussies enter the keysight comp in post #1?
Offline snoopy
    • Analog Precision
« Reply #276 on: February 17, 2017, 04:07:12 am »
Yes you can now enter your country even if it is not on the list ;)
Offline sibeen
« Reply #277 on: February 17, 2017, 04:12:07 am »
in like flin!!
To be grammatically correct it is actually:
"In like Flynn", a reference to the actor Errol Flynn who was known to like a bit.
Offline MrBungle
« Reply #278 on: February 17, 2017, 04:44:21 am »
Yes you can do that but it does not change the eligibility. If you have to enter your country in 'Other' then you are not eligible.
Eligible countries are listed in the T&C's.
Offline bobaruni
« Reply #279 on: February 17, 2017, 05:19:08 am »
Yep, tried to enter and selected "other" as country and error message came up about not being eligible....oh well.
Offline MrBungle
« Reply #280 on: February 17, 2017, 05:26:36 am »
Ah, someone has fixed it then.
I did the same yesterday (for kicks, I knew I wasn't eligible) but it went through no problems.
Offline WackyGerman
« Reply #281 on: February 17, 2017, 10:44:28 am »
:wtf: Is this the 1990's?
No, it's the 50's:
Maximum input voltage 150 Vrms, 200 Vpk
And it comes with switchable probes too.  :palm:
 :scared:
The same shit like the Rigol , Siglent and Rohde & Schwarz . 200 Vpk is the same like 400 Vpk to pk . Not better and not worse . But 400 V on the Siglent and Rigol sells better  :-DD
« Last Edit: February 17, 2017, 10:48:05 am by WackyGerman »
Offline Howardlong
« Reply #282 on: February 17, 2017, 11:36:30 am »
I hate Bode plotters that work with that stepped frequency method.  It not only takes forever to cover the frequency range, but by skipping between discreet frequency steps you can miss resonances/strange behaviors that might happen to be in between the steps.  Real continuous swept sine or full band "white noise" frequency response is sooooo much better and there is nothing keeping an instrument like this from doing either method.
Can you determine phase response from a white noise signal source?
Edit: figured it out... http://www.dr-jordan-design.de/Download/Examples_filter_butterworth.pdf
« Last Edit: February 17, 2017, 11:50:06 am by Howardlong »
Offline snoopy
    • Analog Precision
« Reply #283 on: February 17, 2017, 12:14:39 pm »
Mine went through as well !! Surely with a lot of Agilent representation in Australia and Dave in Sydney they weren't going to ignore us aussies !!
« Reply #284 on: February 17, 2017, 12:57:05 pm »
Dave, are you going to do a comparison between the new Keysight and Rigol 1000z series ?
People probably expect that.
So eventually I guess.
Isn't the Rohde & Schwarz HMO1232 not more in the same league for the X-1000 series than the Rigol 1000z?
Andreas
Offline TheAmmoniacal
  • Country: no
« Reply #285 on: February 17, 2017, 12:58:39 pm »
The question is, can we hack it?  :-/O
Also, no decoding options for the EDUX1002G? Why? That means no/less training signals? CAN? RS232? LIN?
« Last Edit: February 17, 2017, 01:15:46 pm by TheAmmoniacal »
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #286 on: February 17, 2017, 01:30:43 pm »
Thanks Dave for the video.  It looks well made and compared to the market, its really seems designed to replace the aging 1000, deal with the new 2011 RoHS directive older devices, such as the venerable 3458a, have problems with, and unify the UI of its DSO lineup.
If priced right, it could compete in the marker/hobby market.  But, even if priced >= 1054z, it's still cheaper than the 2000X series that advance labs choose over the 1000, save on the AWG and bench space.  Higher end colleges may be in cycle to replace aging labs relatively soon.
https://www.testequity.com/documents/pdf/Agilent_MLPS.pdf
Best Wishes,
 Saturation
Offline tawpgk
« Reply #287 on: February 17, 2017, 01:43:53 pm »
Awesome! Can a long suffering Pisces win one in his birth month? Well maybe it will work...lol
Offline rf-loop
« Reply #288 on: February 17, 2017, 01:48:51 pm »
No, it's the 50's:
 :scared:
Siglent 400Vpk. Keyshit  is 200Vpk.
It is not same as 400Vpp (Vpk to pk)
(in spec sheet: 1 M? ?400 Vpk (DC + Peak AC <=10 kHz)
I have never tested so that I connect 230Vac directly to input.  It have "only" 325Vpk (if it is pure sine). And my scope calibrator (Tek CG5011) have only max 200Vpk @ 10kHz
  :-DD  or |O
« Last Edit: February 17, 2017, 01:54:23 pm by rf-loop »
  • Country: no
« Reply #289 on: February 17, 2017, 02:20:17 pm »
Who really cares what the maximum input voltage on the scope is? You're going to use a 10X probe anyway, just get one which is higher rated.
Online Jay_Diddy_B
« Reply #290 on: February 17, 2017, 02:40:53 pm »
The answer is yes. HP had at least a couple of instruments that could do this the HP3562A and the HP3563A. They are FFT based. I have the control loop of  a switching power supply using a noise source. I had to do this because the power supply could not run for a long enough time for swept or stepped frequency measurements.
With these instruments you can use averaging, so after each measurement you would get better and better results until the result stopped changing.
For a frequency response analyzer, FRA, to be useful for switching power supply measurements, it must reject all frequencies except the frequency being injected. The scope might use FFT to do this.
If Daniel is reading this, I am very disappointed that the FRA (Bode plots) is available for the DSOX3000 T but not the A series. The product is DSOX3PWR
Regards,
Jay_Diddy_B
Offline Keysight DanielBogdanoff
  • ALL THE SCOPES!
    • Keysight Scopes YouTube channel
« Reply #291 on: February 17, 2017, 04:35:30 pm »
Noted
Offline rf-loop
« Reply #292 on: February 17, 2017, 05:03:00 pm »
Of course this is partially true but also it is good to not share "alternative truth" so it was just for correct the false claim. Not for starting any kind debate about this. You do not care. I care, and I need care. Simple.
Offline vtp
« Reply #293 on: February 17, 2017, 05:39:22 pm »
KS 3000T does not seem to do so. It is not very useful in measuring stability of noisy power supplies as it is not a tuned receiver like a VNA - when the measured signals gets noisy the 3000T has massive problems in measuring amplitude and phase. We have also seen 3000T go totally nuts (as in having an EMC susceptibility problem which turns the instrument useless) in measuring a noisy power supply like an off-line flyback.
E5061B however makes a good job of stability measurements, with 3000T we could not complete those measurements at all.
I would be a bit cautious about wanting that option for a 3000 series scope, it may have its uses but at least with us, not so much. YMMV.
Offline AndyC_772
« Reply #294 on: February 17, 2017, 06:18:17 pm »
Noted
I agree, this would be a really nice feature to see on the 3000A X-series. Is there any chance of the code being back ported into the 3000A firmware please Daniel?
Offline WackyGerman
« Reply #295 on: February 17, 2017, 07:13:18 pm »
No, it's the 50's:
 :scared:
  :-DD  or |O
Yes you re right . The 1000X Series has 400 Vp max input . But the older 1000 DL , CML etc. have 400 Vpp input . Sorry for the fault  :-[
Online Monkeh
« Reply #296 on: February 17, 2017, 07:20:26 pm »
I'm sure this has been asked before, but I feel I have to ask it again.
Are you capable of making posts where you don't go around insulting products you don't sell?
Offline MrFox
« Reply #297 on: February 17, 2017, 07:28:14 pm »
No, it's the 50's:
 :scared:
Sorry for the newbie question... I noticed professionals seem to universally hate switchable probes, but how else do you guys measure low level signals? Those of us buying this class of scope will probably not have the money for specialized probes. I mean depending if the specs are good at both settings, it's an attractive choice for budget conscious beginners. :-//
« Reply #298 on: February 17, 2017, 07:45:12 pm »
No, it's the 50's:
 :scared:
For the aged, we did not have switchables, only fixed and you're quite correct switchables are very convenient BUT and big BUT one must be very careful in their use. In the case of this KS using 1:1 probes it could be easy to damage an input with too much voltage applied. US mains voltages are less challenging than most of the rest of the world.
Hence a preference for 400V input rated DSO's.  ;)
The following users thanked this post: MrFox
Offline nctnico
« Reply #299 on: February 17, 2017, 08:16:49 pm »
US mains voltages are less challenging than most of the rest of the world. Hence a preference for 400V input rated DSO's.  ;)
IMHO you are making a way too big deal out of this. When measuring mains like voltages you won't be using a standard 1:1 / 1:10 probe but a differential probe (if you are sane).
The following users thanked this post: Neganur
