The 1000X series seems to be a case of moving relatively mature technology down toward the lower end of the market, now the ASIC development costs have been recovered, where it can be used to up the ante significantly. Presumably, any new Megazoom 5 chip would initially enter at a higher price point. Any competitor coming in against KS entry-level instruments must realise that there is a whole bunch of extra functionality in the MZ4 chip that could, in principle, be turned on at the flip of a firmware upgrade. For example, full ARB generation, extra protocol decodes, extra memory segments, and maybe even extra memory (though it's not clear if the 2nd MZ4 in the 3000+ series is required to enable the full 4Msamples).
There's clearly been some value engineering going on as well. The limited voltage range of the inputs may have allowed a relatively expensive relay to be omitted; the analogue bandwidth may genuinely not go above 100MHz; the expansion connector has been omitted; and a consumer-grade display seems to be used. The two channels only case design also probably helps reduce costs (even if only shipping costs).
Finally, by far the biggest development cost is in the software, and they appear to be re-using software from the 2000X and 3000X family, on an ARM processor (rather than the SHARC devices of the old Rigol-built 1000A/B series). To me it is very interesting that a couple of the higher end features of this software, like the bode plot and FFT phase, have been leapfrogged down to the 1000X. There is clearly more ammunition in the locker that could be brought out if necessary, to meet the competition. Just not huge amounts of acquisition memory.
It will be interesting to see what the educational resource package is like.
