Author Topic: NEW Keysight HD3  (Read 60305 times)
Offline tooki
Re: NEW Keysight HD3
« Reply #300 on: September 01, 2024, 11:48:00 pm »
a) those scopes do not capture outside the screen in run mode
b) even if they did capture outside the screen, that would be compromising the waveform rate
are the 2000x and 3000x series doing something different from the 1000x series?
The 1000X uses the exact same Megazoom IV ASIC.
If it is the exact same chip, then they’re doing something very different with it, since the 1000x and 2000x don’t have anywhere near the waveform update rate of the 3000x and 4000x. (200,000/s for the first two, 1 million/s for the second two.)
Offline Someone
    • send complaints here
« Reply #301 on: September 02, 2024, 01:21:51 am »
Soft/firmware locked/differentiated
Offline simone.pignatti
« Reply #302 on: September 02, 2024, 05:31:48 am »
September 4th is coming and we can't wait to share with everyone the final technical specifications of the new HD3
Technical Support
Offline nfmax
« Reply #303 on: September 02, 2024, 06:05:36 am »
AFAIK the 3000/4000 series have two MZ4 chips, the 1000/2000 only one.
Online EEVblogTopic starter
« Reply #304 on: September 02, 2024, 06:54:42 am »
My HD3 has arrived at Keysight Australia, should have it in a few days I suspect...
The following users thanked this post: egonotto, simone.pignatti
« Reply #305 on: September 02, 2024, 06:55:54 am »
Softsare locked, just like the 2000X is.
Offline jusaca
« Reply #306 on: September 02, 2024, 08:06:55 am »
I'm really curious for your impressions and test. Love the equipment videos. I know these videos make a lot of work, but please take your time for testing =)
« Reply #307 on: September 03, 2024, 07:09:32 am »
It's being picked up today, so I'll probably have it on Thursday, basically the date of release, so I won't have time to have any videos ready for the release.
Offline Hydrawerk
« Reply #308 on: September 03, 2024, 09:50:22 pm »
I am looking forward to HD3.  :-+
Offline Martin72
  • Testfield Technician
« Reply #309 on: September 03, 2024, 09:58:05 pm »
Me too, but only out of curiosity.
If the Scope has nothing else to offer for the expected price apart from the 14 bits, I'm not particularly impressed.
"Comparison is the end of happiness and the beginning of dissatisfaction."(Kierkegaard)
The following users thanked this post: egonotto, KungFuJosh
« Reply #310 on: September 04, 2024, 01:29:02 am »
I do believe it's on the truck for delivery today.
Obviously I don't have time to do a full detailed hour long review before or on the day of release, but please list the stuff you want to specifically see.
Should I do a teardown as soon as I get it, or you you prefer I just test some basic stuff and give a first impressions?
Offline SWB
« Reply #311 on: September 04, 2024, 01:44:19 am »
It's only hours (if that) before the wraps come off officially, but FWIW, the datasheet finally showed up on Google: https://www.4test.no/cosmoshop/default/artikelpdf/HD304MSO_en.pdf
Edit: Straight from Keysight (newer revision than the one above): https://www.keysight.com/us/en/assets/3124-1567/data-sheets/InfiniiVision-HD3-Series-Oscilloscopes.pdf
« Last Edit: September 04, 2024, 08:52:09 am by SWB »
The following users thanked this post: Sparky, egonotto
« Reply #312 on: September 04, 2024, 01:47:42 am »
10 minutes later and here it is!
From "Garden of the Gods Rd"  :-+
The following users thanked this post: Sparky, xrunner, egonotto, tooki, jusaca, the Chris
Offline SWB
« Reply #313 on: September 04, 2024, 01:56:37 am »
I'd enjoy seeing a first impressions video as quickly as you can get one out, followed by teardown and/or full-review video(s) in whichever order you prefer.
The following users thanked this post: EEVblog, egonotto, newbrain, jjoonathan, jusaca
« Reply #314 on: September 04, 2024, 02:07:37 am »
Well an unedited unboxing video would come for free, might as well do that first.
Or I could edit it into a more usable first impressions video, like 2nd channel worthy content maybe.
The following users thanked this post: egonotto, SWB
Offline egonotto
« Reply #315 on: September 04, 2024, 02:18:09 am »
Hello,
an unedited unboxing video and
please can you measure the noise with 50 Ohm and 1 MOhm and 1 mV/div and 1 V/div and 1 ms/div.
Please use a 50 Ohm termination at the input so that there is no interference from outside.
It would be great if you could make the corresponding waveforms available for download. For the download, 1 Mpts would probably suffice.
Best regards
egonotto
« Last Edit: September 04, 2024, 02:20:33 am by egonotto »
« Reply #316 on: September 04, 2024, 02:22:02 am »
The datasheet has noise figures for 50ohm and 1M for many verticals, but I will verify and share data. My standard process is 1ms/div and 1M points anyway.
Offline egonotto
« Reply #317 on: September 04, 2024, 02:22:36 am »
Hello,
congratulations on your new device.
Best regards
egonotto
Offline egonotto
« Reply #318 on: September 04, 2024, 02:28:32 am »
Hello,
thanks, the data sheet doesn't say how they measured it. What is different compared to other devices, however, is that they do not average the values (MXO4 uses HD mode active for bandwidth ≤ 500 MHz).
Best regards
egonotto
Offline SWB
« Reply #319 on: September 04, 2024, 02:43:48 am »
The datasheet suggests there is no roll or XY mode. Really?
I personally haven't had a use for XY mode, but roll is very handy and something I use regularly. The lack of this would be a serious limitation (at least for me).
Edit: Coming soon.
I'm also comparing and contrasting the HD3 datasheet with that of my current 3000 X-Series. It's interesting that there are a few specs where the 3000 X actually outperforms the HD3. Existence of roll and XY is one. Another is the maximum sample rate. The 3000 X can do up to 4 GSa/s (5 GSa/s for the 1 GHz model), while the HD3 maxes out at 3.2 GSa/s. But that comes with an asterisk, because the HD3 can do its full rate regardless of how many channels are active, while the 3000 X drops to half of its maximum value if more than 2 channels are active.
« Last Edit: September 04, 2024, 06:53:20 am by SWB »
Offline egonotto
« Reply #320 on: September 04, 2024, 02:58:29 am »
Hello,
perhaps you can also measure Vpp during the noise measurement. that would also be very interesting.
Best regards
egonotto
Offline egonotto
« Reply #321 on: September 04, 2024, 03:04:16 am »
Hello,
can you call the HD3 a gray mouse, or would that be an insult?
Best regards
egonotto
Online Anthocyanina
  • The Sara
« Reply #322 on: September 04, 2024, 04:06:29 am »
so they did name it megazoom 5 but got rid of the megazoom logo on the scope! i liked the logo! oh well :-//
Offline georgd
  • Country: cs
« Reply #323 on: September 04, 2024, 04:24:24 am »
Here is a new video about HD3:
When I discovered this video, I was the third viewer.
The following users thanked this post: EEVblog, egonotto, HighVoltage, tooki
Online Anthocyanina
  • The Sara
« Reply #324 on: September 04, 2024, 04:25:42 am »
and the intensity grading, at 16 intensity levels, is worse than in the 3000x series which states 64 levels!
