MVSantos and 4 Guests are viewing this topic.
Quote from: Anthocyanina on August 30, 2024, 11:51:25 amQuote from: Someone on August 30, 2024, 10:27:15 ama) those scopes do not capture outside the screen in run modeb) even if they did capture outside the screen, that would be compromising the waveform rateare the 2000x and 3000x series doing something different from the 1000x series?The 1000X uses the exact same Megazoom IV ASIC.
Quote from: EEVblog on September 01, 2024, 01:06:16 amQuote from: Anthocyanina on August 30, 2024, 11:51:25 amQuote from: Someone on August 30, 2024, 10:27:15 ama) those scopes do not capture outside the screen in run modeb) even if they did capture outside the screen, that would be compromising the waveform rateare the 2000x and 3000x series doing something different from the 1000x series?The 1000X uses the exact same Megazoom IV ASIC.If it is the exact same chip, then they’re doing something very different with it, since the 1000x and 2000x don’t have anywhere near the waveform update rate of the 3000x and 4000x. (200,000/s for the first two, 1 million/s for the second two.)
Quote from: tooki on September 01, 2024, 11:48:00 pmQuote from: EEVblog on September 01, 2024, 01:06:16 amQuote from: Anthocyanina on August 30, 2024, 11:51:25 amQuote from: Someone on August 30, 2024, 10:27:15 ama) those scopes do not capture outside the screen in run modeb) even if they did capture outside the screen, that would be compromising the waveform rateare the 2000x and 3000x series doing something different from the 1000x series?The 1000X uses the exact same Megazoom IV ASIC.If it is the exact same chip, then they’re doing something very different with it, since the 1000x and 2000x don’t have anywhere near the waveform update rate of the 3000x and 4000x. (200,000/s for the first two, 1 million/s for the second two.)Soft/firmware locked/differentiated
Quote from: EEVblog on September 01, 2024, 01:06:16 amThe 1000X uses the exact same Megazoom IV ASIC.If it is the exact same chip, then they’re doing something very different with it, since the 1000x and 2000x don’t have anywhere near the waveform update rate of the 3000x and 4000x. (200,000/s for the first two, 1 million/s for the second two.)
My HD3 has arrived at Keysight Australia, should have it in a few days I suspect...
Quote from: EEVblog on September 02, 2024, 06:54:42 amMy HD3 has arrived at Keysight Australia, should have it in a few days I suspect...I'm really curious for your impressions and test. Love the equipment videos. I know these videos make a lot of work, but please take your time for testing =)
Should I do a teardown as soon as I get it, or you you prefer I just test some basic stuff and give a first impressions?
Quote from: EEVblog on September 04, 2024, 01:29:02 amShould I do a teardown as soon as I get it, or you you prefer I just test some basic stuff and give a first impressions?I'd enjoy seeing a first impressions video as quickly as you can get one out, followed by teardown and/or full-review video(s) in whichever order you prefer.
please can you measure the noise with 50 Ohm and 1 MOhm and 1 mV/div and 1 V/div and 1 ms/div. Please use a 50 Ohm termination at the input so that there is no interference from outside.It would be great if you could make the corresponding waveforms available for download. For the download, 1 Mpts would probably suffice.
