Author Topic: NEW Keysight HD3  (Read 16172 times)
adam.v, SWB and 11 Guests are viewing this topic.
Offline tooki
Re: NEW Keysight HD3
« Reply #175 on: August 22, 2024, 09:25:01 pm »
I haven't seen the full datasheet
Speak of the devil  8)
Hmm, haven't found the datasheet, but I did find two PDF app notes via Bing that are pretty revealing. ;)
Please provide direct links, since none of the results I’m seeing appear related. (The results may vary by geographic location, or they may have been delisted.)
The following users thanked this post: egonotto, Martin72
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #176 on: August 22, 2024, 09:27:24 pm »
http://www.jays.co.kr/12_Files/Debug%20Automotive%20Serial%20Buses%20Quickly.pdf
http://jays.co.kr/12_Files/How%20to%20Make%20Ripple%20and%20Noise%20Measurements.pdf
This is about the only interesting stuff from the appnotes :
See What You’ve Been Missing
4x the resolution and up to 10x less noise
The HD3 Series brings Keysight’s industry-leading capabilities from high-performance scopes to the high-
volume level, making precision portable from 200 MHz to 1 GHz. Leveraging custom hardware
technology from the UXR Series, the HD3 boasts the most impressive resolution on the market with 4x
the vertical accuracy and up to 10x less noise than the competition. Paired with our fast, uncompromised
waveform update rate and 25x more memory, the HD3 Series is truly set apart from other oscilloscopes in
this class.
« Last Edit: August 22, 2024, 09:30:18 pm by mikeselectricstuff »
Day Job: Mostly LEDs
Online jc101
« Reply #177 on: August 22, 2024, 09:30:27 pm »
Reassuringly expensive no doubt, especially as many features will probably be additional licences, maybe even rented ones too.
Looks nice though.
Offline tautech
« Reply #178 on: August 22, 2024, 09:31:40 pm »
this class.
Where's the MSO ?
Offline Anthocyanina
  • The Sara
« Reply #179 on: August 22, 2024, 09:31:48 pm »
...Leveraging custom hardware
this class.
i missed this bit. that explains the lack of a megazoom logo. so I guess megazoom 4 will be the last in the megazoom family?
Online Martin72
  • Testfield Technician
« Reply #180 on: August 22, 2024, 09:41:25 pm »
Looks a bit clunky....
We will know more next month, as a data sheet will then also be available.
(Kierkegaard)
Offline thm_w
  • Non-expert
« Reply #181 on: August 22, 2024, 09:46:02 pm »
Doesn't really look like a $20k scope to me. Guess the MSO stuff is on the back?
edit: they show the noise in that document
- 422uVp-p 50uV RMS at 1mV + 50Ohm
- 871uVp-p 96uV RMS at 1mV + 1MOhm
« Last Edit: August 22, 2024, 10:14:04 pm by thm_w »
« Reply #182 on: August 22, 2024, 09:46:39 pm »
Where's the MSO ?
Looks like the same probe as the previous models
Online nctnico
« Reply #183 on: August 22, 2024, 09:47:03 pm »
And the screen is super tiny. If those pictures are the real thing, I think the HD3 is a flop due to the screen size alone. That is like an 8" or 9" 16:10 screen.
« Last Edit: August 22, 2024, 09:50:27 pm by nctnico »
The following users thanked this post: egonotto, thm_w
Offline thm_w
  • Non-expert
« Reply #184 on: August 22, 2024, 09:55:08 pm »
Measuring the image gave me a usable screen area of ~10.4"
Online Martin72
« Reply #185 on: August 22, 2024, 09:55:55 pm »
This actually looks even smaller than 10” in relation to the BNC sockets.
That would be a disappointment, in the expected price range at least 12” is the standard.
(Kierkegaard)
Offline 2N3055
  • Country: hr
« Reply #186 on: August 22, 2024, 10:01:37 pm »
- 422uVp-p 50uV RMS at 50Ohm
- 871uVp-p 96uV RMS at 1MOhm
Make note that BW was not specified for those measurement.
10x less noise is also bogus claim.
Even if 49µV RMS was at full 1GHz BW, competition does not have 500µV RMS of noise at 1mv/div at 100us/div...
Also scope shows 3.2 GS/s with 1 and 2 ch enabled. I could not find image with 3 or 4 enabled.
It seems 100MPts/ch is max. (that is great improvement over old ones.)
« Last Edit: August 22, 2024, 10:08:44 pm by 2N3055 »
The following users thanked this post: Someone, egonotto, thm_w
Offline temperance
« Reply #187 on: August 22, 2024, 10:28:10 pm »
Is anything known about The Handle? In terms of scent and color, Ceder wood would be nice I think and it keeps moths away.
The following users thanked this post: 2N3055, jusaca
Offline tszaboo
« Reply #188 on: August 22, 2024, 10:36:09 pm »
So it's not just me. I really like the shape of the MSOX 3000 series, this feels like a step back in terms of design. Maybe it's better IRL.
Offline temperance
« Reply #189 on: August 22, 2024, 11:01:55 pm »
I don't know why all manufacturers are going back in time with only one set of knobs to operate all channels. I find that somehow annoying.
The following users thanked this post: Brumby, tooki, jusaca
Offline EEVblogTopic starter
« Reply #190 on: August 22, 2024, 11:07:37 pm »
There are no rented licenses according the datasheet. But of course al lthe usual suspects are there as upgrades.
« Reply #191 on: August 22, 2024, 11:08:20 pm »
There isn't really a choice when you have a modern big screen and 4 channels.
« Reply #192 on: August 22, 2024, 11:12:51 pm »
I'm not revealing much now by saying it's 10.1"
The following users thanked this post: thm_w, Martin72
« Reply #193 on: August 22, 2024, 11:15:44 pm »
Where's the MSO ?
Different part number, but indeed looks the same physically, in whcih case that's really nice. I have when manufacturers change probes. Maybe it has to be a different part number because it comes with the license code in the box?
« Reply #194 on: August 22, 2024, 11:21:49 pm »
 8)
Offline temperance
« Reply #195 on: August 22, 2024, 11:25:31 pm »
A DSOX60 isn't that large with it's 15" TFT. About 40 cm wide.
Online m98
« Reply #196 on: August 22, 2024, 11:29:36 pm »
Did they outsource their industrial design to Yokogawa?
  • The Sara
« Reply #197 on: August 22, 2024, 11:35:29 pm »
with that screen size it seems it's about as wide as the current 1000x series, maybe just a little bit wider, so this is quite compact horizontally. I wonder why they went for the chonky compact design
Online ArdWar
  • Country: sc
« Reply #198 on: August 23, 2024, 12:02:32 am »
I'm not going to speculate on the specs or UX yet, but I don't like the control layout. This form factor only emphasize one thing I always hate with HPAK's design language... why are they hellbent on separating the vertical and horizontal control so far away? It's a s if they want to put them as far as possible from each other.
« Reply #199 on: August 23, 2024, 01:26:37 am »
I rather like it. I like having the Horizontal at the top completely away from the Veritcal below.
I was using the Tek MDO3000 the other day, and boy how to I hate that Horizontal knob placement.
The following users thanked this post: bergenhut
