Author Topic: NEW Keysight HD3  (Read 50589 times)
Re: NEW Keysight HD3
« Reply #125 on: August 18, 2024, 12:24:24 pm »
The SDS3000X HD is specced at 125uV RMS @1GHz, and it's not the best on the market.
It would also be quite embarrassing for others if the cheapest 1GHz scope was also the “best” in terms of noise on the market.
It's certainly not the worst either.
We wait and see..
What, any dimwit can use a screwdriver.  :-DD
Offline 2N3055
  • Country: hr
« Reply #126 on: August 18, 2024, 05:48:34 pm »
We wait and see..
My SDS3000X HD has 130uV RMS @1GHz BW at 10 mV/div.. by the way..
The data points I've seen from the Siglent HD models overlaps identically with the Lecroy data above (unsurpisingly).
Good observation. Some do, some don't.
Scope's front end is designed according to input sensitivity/offset/amp stages/attenuator stages plan.. If you have similar plans numbers start to converge.
Being OEM for some LeCroys and long cooperation with them will definitely have influence to "flavour" of scopes Siglent makes.
But there are some Siglent scopes  that have front ends that are unique, having large offset ranges not many others have...
Online EEVblogTopic starter
« Reply #127 on: August 18, 2024, 10:32:31 pm »
the SDS3104X HD has less than 6 mV RMS noise at 1 GHz and 50 ohms and 1 V/div and 1 ms/div and 40 Mpts and 4 Gpts/s. Only LeCroy can beat that. With other time and memory settings, the SDS3104X HD can also be brought below 5 mV noise.
When I get it, I'll measure it. But according the specs, the noise is indeed half of the best competitor on the 2mV range. 1V is not specified in the info I have.
And in case anyone has missed mention of it, the HD3 has more resolution than all the competitors.
The following users thanked this post: egonotto, jusaca
Offline 2N3055
  • Country: hr
« Reply #128 on: August 18, 2024, 10:43:11 pm »
All scopes will have different sweet spots..
14 bits sounds nice, ENOB is better...
So we are saying 50-66µV RMS at 1GHz BW at 2mV/div....
As I said we'll see in few weeks. I don't expect Keysight to do it incompetently. We'll see how far they could push it though.
Offline nctnico
« Reply #129 on: August 18, 2024, 11:06:41 pm »
Unless it is some kind of high-res mode. Realistically, having more than 12 bits with hundreds of MHz of bandwidth requires an insanely low jitter / low phase noise sampling clock. Otherwise the jitter / phase noise by itself messes up the ENOB big time. So for actual measurements it makes sense to trade bandwidth for more bits / resolution.
The following users thanked this post: egonotto, pdenisowski
« Reply #130 on: August 18, 2024, 11:20:12 pm »
I'm sure Keysight are aware of this.
The following users thanked this post: egonotto, Keysight DanielBogdanoff
Offline mawyatt
« Reply #131 on: August 18, 2024, 11:42:46 pm »
Could this be the First Commercial use of the Non-Uniform Sampling ADC championed by Dr Mike Chen at USC almost 2 decades ago :-+
The NUS ADC certainly found uses it "other" places  ::)
BTW KS was very interesting in this ADC, Dr Chen had a few visits from some very famous KS folks!!
Here's an image of an early rendition NUS ADC in TSMC 65nm CMOS ;)
Later KS were developing interesting ADCs of their own, like this 2nd image :-+
Best,
« Last Edit: August 18, 2024, 11:50:28 pm by mawyatt »
~Wyatt Labs by Mike~
The following users thanked this post: EEVblog, egonotto, Kean, newbrain, jjoonathan, jusaca, wolfy007, pdenisowski
« Reply #132 on: August 18, 2024, 11:48:19 pm »
Damn that's a gorgeous photo!
The following users thanked this post: egonotto, jjoonathan
« Reply #133 on: August 18, 2024, 11:53:48 pm »
Best,
Not signed by yours truly ?
Offline mawyatt
« Reply #134 on: August 19, 2024, 12:01:04 am »
Thanks, we started developing Chip Imaging techniques and equipment back in 2000. Everything was custom developed from the lenses, setup, focus rails, even the lighting, software and so on!
Some folks wanted us to start company doing such, but we resisted. Becoming a "Chip Photographer" wasn't what we had in mind as our career wound down!!
We have a bunch of Specialized and Custom Chip images, some we still can't revel, but hopefully someday as we've recently been informed that some of our very old work may become public and put on display at a specialized museum., we shall see :)
Best,
The following users thanked this post: EEVblog, egonotto, Kean, tooki, 2N3055, Jacon, wolfy007, pdenisowski, rteodor
Offline mawyatt
« Reply #135 on: August 19, 2024, 12:02:45 am »
Best,
 ;D
Best,
The following users thanked this post: egonotto, 2N3055
« Reply #136 on: August 19, 2024, 12:16:19 am »
Tha reminds me, I have to arrange that Amp Hour podcast we were going to do!
Offline mawyatt
« Reply #137 on: August 19, 2024, 01:19:55 am »
Here's another Low Resolution Image of the NUS ADC you might like.
Best,
The following users thanked this post: EEVblog, egonotto, tautech, newbrain, 2N3055
« Reply #138 on: August 19, 2024, 01:26:51 am »
Just distinguishable since I know what to look for, bottom right, correct ?
Offline mawyatt
« Reply #139 on: August 19, 2024, 01:47:50 am »
There's some text hidden under the wire bonds, if you look on the right middle there's more text. This is "MOSIS" which is chip fabrication aggregator, but the chip was actually fabricated at TSMC.
Best,
Offline mawyatt
« Reply #140 on: August 20, 2024, 12:39:39 pm »
Hey Dave, if we're correct about the new Keysight HD3 using the NUS ADC, do we win the HD3 as a "prize"  ;D
BTW interested folks should look into this NUS ADC. Simultaneously quantizing in Amplitude and Time opens up a completely new Signal Processing Path, like post Analog to Digital Conversion Anti-Aliasing Filtering :-+
https://www.eevblog.com/forum/metrology/why-dont-we-see-more-tdc-based-high-resolution-adcs/msg5484382/#msg5484382
Best,
« Last Edit: August 20, 2024, 01:12:38 pm by mawyatt »
« Reply #141 on: August 21, 2024, 12:11:01 am »
I asked them about that actually, and they said they'll ask R&D. So it sounds like like there is no marketing info boasting about it.
The following users thanked this post: thm_w, pdenisowski
Offline nctnico
« Reply #142 on: August 21, 2024, 09:42:48 am »
I don't think a NUS ADC solves much problems except for bringing the anti-aliasing filter into the digital domain. I looked into it a bit and what a NUS ADC does is look at the input voltage continuously through the input comparator section and produce a value pair consisting of time and amplitude  when the comparator section senses an input voltage variation. However, quantizing time using a TDC (time to digital converter) for example, is bound to limits (as Mr Chen also notes in his video). Getting into the tens of fs time resolution with a TDC is hard. I know this because I had reason to ask this question to a specialist IC designer for a project I'm involved in. So in the end you still have what is an equivalent to aperture jitter which is in the same ballpark as a good conventional high speed ADC.
« Last Edit: August 21, 2024, 09:48:58 am by nctnico »
Offline jusaca
« Reply #143 on: August 21, 2024, 10:35:47 am »
But he also mentions some bold claimes of up to 30 dB noise advantage compared to classic ADCs, although I could not follow the reasoning while watching that IEEE presentation.
Offline pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #144 on: August 21, 2024, 10:37:14 am »
In my experience, any ground-breaking / game-changing / unique features of a new product usually are very widely known within the company, especially less than a month before launch.  If someone has to ask R&D about a new product feature, it very likely either isn't there or isn't that important :)
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
The following users thanked this post: Someone, egonotto, 2N3055
Offline nctnico
« Reply #145 on: August 21, 2024, 11:25:08 am »
The way I see this, NUS only has a benefit for relatively low frequency signals. If you can measure the time in single picoseconds while sampling a 10MHz signal, you have an effective samplerate of 1Gs/s without needing to process 1Gs/s. The extra effective samplerate gives you much more headroom in a digital anti-aliasing filter. The idea is pretty clever though but not new. Signals in the 10's of MHZ are typically found in modern wideband radio communication systems like Wifi, LTE, 5G, 6G. Later on the video you'll see Mr Chen shows some of these typical radio applications. But all of these work with demodulated signals in the 10's of MHz range.
« Last Edit: August 21, 2024, 11:28:06 am by nctnico »
Offline Keysight DanielBogdanoff
  • ALL THE SCOPES!
    • Keysight Scopes YouTube channel
« Reply #146 on: August 21, 2024, 05:15:09 pm »
We design our own ADCs, and usually go to one of the big fab houses to make them (unless it's one of our InP chips which we do ourselves in Santa Rosa). No InP on the HD3 to my knowledge. We do have a couple more traditional fabs, but those are used for lower volume / specialty chips.
The following users thanked this post: EEVblog, egonotto, jjoonathan
Offline mawyatt
« Reply #147 on: August 21, 2024, 05:52:22 pm »
We know, here's an early experimental KS Custom Really Really Fast "Stingray" 10 bit CMOS ADC :-+
We first witnessed the amazing SiGe BiCMOS Griffin DAC way back (have images also if interested), that's how we got know some KS folks. Later designed a couple early experimental InP chips fabbed at Santa Rosa, images if interested.
KS Santa Rosa had a group of some of the best, if not the best, World Class Designers we had ever encountered, hope they still do!!
Best,
« Last Edit: August 21, 2024, 06:08:36 pm by mawyatt »
The following users thanked this post: egonotto, Keysight DanielBogdanoff, jjoonathan
Offline jjoonathan
« Reply #148 on: August 21, 2024, 05:52:54 pm »
I dunno if another one of these "inside scoop" presentations is in order, but this one for the Stingray ADC was super cool: https://youtu.be/pdbzIwelCL4?t=99
The following users thanked this post: EEVblog, egonotto, mawyatt
Offline tggzzz
« Reply #149 on: August 21, 2024, 05:53:33 pm »
Back in the 80s, I knew one of the people who created those - Tom Horňak. Nice guy. (Back then 1GHz bandwidth, 6bit was state of the art)
Good to see "the real HP" is keeping up the tradition :)
