Hello,
Bad__Driver gave me a hint to look in the manual of the SDS3000X HD.
There you can read that you should switch on “adaptive sample rate”.
If you want to set a certain cut-off frequency fg for the low-pass filter, the sample rate must be between 4*fg and 100*fg.
At 1 kHZ cut-off frequency, the sample rate must therefore be between 4 kHz and 100 kHz.
At a cut-off frequency of 10 Hz, the sample rate must be between 40 Hz and 1 kHz.
@Someone: What are the conditions for the sample rate for Keysight 1000x, 2000x, 3000x if you want to set the cut-off frequency of a LP filter at 10 Hz?
Best regards
egonotto
