tv84, Jay_Diddy_B, georgd, Keysight DanielBogdanoff, KE5FX, Sparky, Lukas, Bad_Driver, SingleBitError, jc101, pico61, Antonio90, Wolfgang, mahi, artur0089, jashugan, LuisBe and 12 Guests are viewing this topic.
Ah yes, the "high impedance" *10 1GHz passive probes.
Ah yes, the "high impedance" *10 1GHz passive probes.Their impedance at 1GHz is actually j40 // 10M . Note the irrelevance of the 10M and the lack of zeros in 40 , due to the 4pF tip capacitance For comparison my 1.5GHz *10 HP10020A passive probes (introduced in 1978!) are >j230 // 500 Note the significantly reduced loading due to the <0.7pF tip capacitance
The update rate that does not change is all great, but it's clear that measurements are done on only a small fraction of waveforms.
Quote from: tggzzz on Today at 11:36:45 amAh yes, the "high impedance" *10 1GHz passive probes.Their tagline for their "new" probe is HiZ+ Hi Voltage. So I guess they want to keep R at 10M for that 300V rating, which compromise the tip capacitance.
Quote from: tggzzz on Today at 11:36:45 amAh yes, the "high impedance" *10 1GHz passive probes.Their impedance at 1GHz is actually j40 // 10M . Note the irrelevance of the 10M and the lack of zeros in 40 , due to the 4pF tip capacitance For comparison my 1.5GHz *10 HP10020A passive probes (introduced in 1978!) are >j230 // 500 Note the significantly reduced loading due to the <0.7pF tip capacitance And still 500R at DC instead of 10M My probe that cost a couple of bucks is probably just as good, 13:50
All that matters is the final measurement update rate, 7 times faster is still 7 times faster, AND you still keep the high update rate for capture as well.
Does it support Ali-pay, Apple pay and Google pay? Tap your phone to have 10 minutes of protocol decoding.
Quote from: nctnico on Yesterday at 07:03:02 pmDoes it support Ali-pay, Apple pay and Google pay? Tap your phone to have 10 minutes of protocol decoding.Honestly, I wish the scope makers were willing to rent expensive options for short periods, precisely for when you just need it for a bit.
Do we have a 10MHz reference output?
Why do they have the illuminated buttons and also the LEDs next to them? Do they do different things?
Quote from: tooki on Today at 02:45:37 pmQuote from: nctnico on Yesterday at 07:03:02 pmDoes it support Ali-pay, Apple pay and Google pay? Tap your phone to have 10 minutes of protocol decoding.Honestly, I wish the scope makers were willing to rent expensive options for short periods, precisely for when you just need it for a bit.From all that I know, only R&S has currently a licensing scheme that would easily allow such feature. A nightmare for all others.
How do you figure? As best I can tell, all the scope makers support time-limited “demos” of individual option licenses. It’s just that right now, their reps can give those out for free for testing, but usually just once or twice before their bosses get mad. I wish they just sold those time-limited licenses so we could just license certain features as needed.
Quote from: mikeselectricstuff on Today at 12:58:23 pmWhy do they have the illuminated buttons and also the LEDs next to them? Do they do different things?I think:The button illumination indicates the channel is being displayed on the screen.The LEDs indicate which channel the gain and offset knobs will modify.Regards,Jay_Diddy_B
37:10 - 14bit ADC TESTED
Quote from: EEVblog on Today at 12:46:57 pmAll that matters is the final measurement update rate, 7 times faster is still 7 times faster, AND you still keep the high update rate for capture as well.What I am missing:- As locking for the maximal FFT size (somewhere mentioned HD3 as 32M FFT) as may licensed memory dependent. This would anyway lower the update rate. While did not find any specifications.- How the ENOB on 100uV as may 200uV too will show up and how the noise will be.- The internal reference oscillator PN specifications and nothing about the synthesizer jitter in various time/div- Do we have a 10MHz reference output?- FFT with rtHz scaling, this would knock out many others from Asia
