I've been considering something like this because it goes to 1.5 GHz and covers ham bands thru 33 and 23 cm. ( I have an Agilent E6380A which skips 23cm/1240 MHz.) Use will be for sweep filters, check antennas and trouble shooting in the HF & VHF bands as well. What are the pros and cons? Also what are other not quite boat anchors to consider and not spend $1000.00 that have a reliability track record?
I'd like to get the Siglent SSA3032 and could stretch my budget but have a hard time justifying the expense. Aside from its' features, specs, and size it has a 3 yr warranty and my credit card doubles manufacturers warranties. So in the end this might make more sense if I wasn't trying to be thrifty.
One of my friends suggests considering a Rohde FSH3 instead of the Siglent???
I should mention that I've had 2 different HP 141 & TG, an old Advantest can remember model but it wouldn't stay working, Anritsu MS2670A and now HP 8935. I'm nearly 79 so this will be my last SA if I can figure out which one meets my fancy.
Thanks
Hank
