Good. The caps are not the problem. Please check the missing CR2703. You don't have to find it. It's connected to C2711 and C2712. Make a diode test at the leads of the caps (yellow arrows).
Thanks.
It did measure "nothing" both ways, with the diode-test. Even at 20M-scale, the leads of the caps are open.
Because of trouble with soldering these bastards in again, i lifted C2711, i thought it was a cold joint - Guess what, there is something hiding under there, more correct it is hiding under C2724 hidden by C2711.
Could this one be the problem?
Why are this thing so hard to solder? One end of both caps went fine, the other is just impossible. I did use flux, the solder just don't want, what i want it to. Need to clean up with some wick, and try again, when the cap need to be soldered in again.
What diode do i need for replacement?
