In my opinion, this is a very decent meter for advanced bench-usage.
I like the new approach on the user-interface.
Every setting related to the actual measurement-mode is easily and contextual sorted available. And it reminds you to frequently wash hands
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
I also like, that there is no need to employ your computer to do some quick-setup monitoring and trending.
There, i would find it very useful to have a reset button for the limits if you set "Auto Clear" to off and one ore both limit(s) to on. One Button for both would be absolute ok.
For example, you just want to know if a monitored voltage trips the limit somewere in time. You set up the scenario and turn your intrerest to the thing on the other bench.
Somewhat later your back and "oh it has tripped - lets do this and that and give it another go"
You just had to press the (imaginary yet) reset-button instead of fiddeling around with the limit-settings.
(The actual setting of the limit-related stuff is imho fine)
This might be done via TSP-Script, and hae a Button on the user-swipe, but if it whre in the firmware ...
![](https://www.eevblog.com/forum/testgear/new-keithley-dmm6500/?action=dlattach;attach=1043970;image)
