About provide syntax:
Thanks, I will try when I'm at work.
About github: nice one!!
I'm thinking about using standard deviation in the sample and hold script and less fine tune settings, the script should figure it out on its own, should avoid the false 'holds' that I got when tested.
But may require a higher sample rate, idea for later.
About 10Gohm:
is there a way to force it to 10Gohm instead of Auto?
When I want to use it I don't want it to change its mind for a few second and then go back to 10Gohm
I need to be able to count on it that it's not 10Mohm.
Also since it's come up again, we are working on an FFT app, but it doesn't work on the currently released firmware. Plus we'll see how it compares to all the FFT work everyone else has been doing!
Nice, you do know that it's not fair competition since you have more doc. and you can optimize the firmware for it
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
about the kickstart license:
At Farrnell.be, .uk also involved, they are still trying to figure out what to do...
If only Tektronix had a website platform to register your device and redeem your copy without having to email anyone to get it. Oh wait, they do, they just didn't use it (correctly), would have made it so much easier for everyone.
But everyone is friendly
trying to help.
I also contacted conrad.be to know what their procedure is because the software isn't on their website....
It's becoming more likely that I will buy a DMM6500 for myself
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
(I still have a DM3068 now)
At home I'm living by the rule don't pay for calibration, buy a new DMM
edit reply of conrad.be in Dutch:
Basically they have no knowledge of it and advice to contact tektronix with your proof of purchase to get your license.
Their supply is from Germany.
Ons is niet bekend hoe de door u genoemde licentiecode verzonden wordt en/of dat deze al bij het apparaat meegeleverd wordt.
Wij leveren vanuit ons magazijn in Wernberg, Zuid-Duitsland en betrekken de artikelen via ons Duits moederbedrijf.
Het kan dus zijn dat als deze actie landgebonden is er bij de "Duitse" versie geen licentie wordt verstrekt.
Ons advies is dan ook even contact op te nemen met Tectronics via het in de link gepubliceerde telefoonnummer: 00800 2255 4835
Het lijkt er echter op dat als je de meter aanschaft en een bewijs van aankoop kunt overleggen aan Tectronics deze u dan de genoemde licentiecode zal mailen.
De software is sowieso al op voorhand te downloaden via de website van Tektronics.
