Electrically, it should work with the same screen size, resolution, and controller.
But mechanically, I don't think it can be installed. It is better to purchase the same LCD panel or replace the polarizer.
As I thought, I initially mistakenly thought it was caused by the aging of the polarizer, but please see the following picture
The entire screen is made of a horizontal liquid crystal and a vertical liquid crystal bonded together.The horizontal direction is welded by zebra strips, and the vertical direction is conductive rubber.
I guess it's because the glue that bonds them together has aged.
If I buy the same model, I estimate that the same problem will occur again after a period of time, so I hope to completely solve this problem.
