Author Topic: It's OK now! was->Help - it's broken! was->Tektronix 2467b - ok for beginner?  (Read 11093 times)
Offline ModemJunkiTopic starter
Re: Help - it's broken! - was->Tektronix 2467b - ok for beginner?
« Reply #25 on: May 26, 2013, 12:21:45 am »
Thanks for catching that.
I got the 10 ohm figure from this YouTube video, at about 1:21 he talks about one of the lights being out and using a 10-ohm resistor to bridge the circuit.
The good bulb measures 5.6 ohms, of course that doesn't work for circuit design with incandescent bulbs. :-)
« Reply #26 on: May 26, 2013, 03:33:29 am »
All right, I think it's sorted. ;)
Thanks again for all the help!
Here are pictures of: the repaired cable folded so it does not ride out and contact the chassis cover, an extra accessory that I found in the rubbish bin at work, the signal from a P6137 probe connected to the calibration point with "Auto" pressed, and automatic voltage and frequency measurements from the same.
Offline c4757p
  • adieu
Awesome! :-+
Offline jancumps
  • New Low
Well done, nice fix! Like it very much.
Offline JimmyMz
I'd use a 1W resistor for the 43 Ohm resistor, based on my calculations the power dissipation across the resistor will be ~560mW. This info. is only helpful if you plan to temporarily fix the lamp issue. Good luck  :)  http://www.ebay.com/itm/50pcs-43-ohm-Metal-Film-Resistor-1W-1-New-1-Watt-High-Quality-/300856860973?pt=LH_DefaultDomain_0&hash=item460c77612d
« Last Edit: May 27, 2013, 04:27:44 am by JimmyMz »
If you didn't get this message, let me know, and I'll get you another.
