Author Topic: New Hantek DSO2X1X models?  (Read 445687 times)
0 Members and 13 Guests are viewing this topic.
Offline masta_k74
Re: New Hantek DSO2X1X models?
« Reply #1275 on: November 19, 2022, 03:39:49 pm »
Where did you buy the caps? I currently have a problem with two photodiodes "BPW24R" from AliExpress. Both from the same seller there. They are definitely not photodiodes, not even normal diodes, but simply empty housings. There is no measurable value, no diode path, no resistance, no voltage when irradiated with light, nothing. It seems to me that there is a growing problem with fake components. Unfortunately, I have had the photodiodes here for a long time and can no longer complain about them. Unfortunately, I was stupid enough to trust the seller and did not check them immediately. |O
The following users thanked this post: eevbstedt
Offline Russ3000
  • Country: il
« Reply #1276 on: November 19, 2022, 08:03:22 pm »
I put the batteries in, glued everything to the front panel, it works fine, there is no noise at all.
I had to put resistors on the 2x9 output, the block did not start at a large input capacitance 7805 and 7905
An open probe at maximum sensitivity, I did not expect this.
« Last Edit: November 19, 2022, 08:11:25 pm by Russ3000 »
Offline nokin
  • Country: vn
« Reply #1277 on: November 20, 2022, 12:30:22 am »
Mine was bricked last night, I think no way to recovering.
The osc can boots then hangs, no response from any key and NO TRACEs !  Front input area are quite hot when I touched the shields. Don't know why.
Everything was ok before. I checked again volts at all test points on mainboard are ok for both analog and digital section.
Win11 could see the rear usb plugged in FEL mode but cannot install driver (winusb).
« Last Edit: November 20, 2022, 12:37:53 am by nokin »
Online DavidAlfa
« Reply #1278 on: November 20, 2022, 12:38:58 am »
Why can't you install the driver?
Check out the Automated driver installer.
The following users thanked this post: eevbstedt, nokin
Offline nokin
  • Country: vn
« Reply #1279 on: November 20, 2022, 01:51:14 am »
Thanks DavidAlfa, I will try and report later.
Something wrong in front input section, they quite hot on shield's surfaces. No traces on lcd.
Offline nokin
  • Country: vn
« Reply #1280 on: November 20, 2022, 02:25:10 am »
 I got mine from damaged genuine audio board. I think oscons are best for digital decoupling but not for usb devices related. This is the 2nd time I met this problem. Last bug was PCIe to usb 3.0 card on my music server, the computer even not recognize Amanero board.
« Last Edit: November 20, 2022, 02:26:57 am by nokin »
Offline masta_k74
« Reply #1281 on: November 20, 2022, 05:24:49 am »
You say the input area on the front panel gets very hot? Have you checked all three voltages? If something has gone wrong with the power supply due to the changes, that could well be the case. Above all, it doesn't have to happen immediately. I would check this first, before a voltage that is possibly too high destroys everything. :-BROKE
Offline nokin
  • Country: vn
« Reply #1282 on: November 20, 2022, 05:56:38 am »
Hi DavidAlfa,
I've tried many times on both win 10 vs win 11, even win 10 never ever plugged osc before, but same problem with driver installing.
Tried zadig driver it was installed successful but Device manager still showed Unknown Devices #1. Restore.bat still "waiting for any devices"
Offline nokin
  • Country: vn
« Reply #1283 on: November 20, 2022, 05:59:47 am »
Yes, until now 2 shields still hot (or warm). 7v and 5v rails are ok. I've measured on 4 test point dots on mainboard.
Quite strange but I don't know what happened. Maybe these front input shortened but cannot happened for both channels.
Offline nokin
  • Country: vn
« Reply #1284 on: November 20, 2022, 06:06:10 am »
Opened shield covers, I see U27 and U24 very hot. So problem are here but what happened before I really don't know.
Maybe these ICs were shortened circuit.
Online DavidAlfa
« Reply #1285 on: November 20, 2022, 06:39:26 am »
Strange, I've tested it in both win7 and win11.
What about manual Zadig installation?
The following users thanked this post: nokin
Offline nokin
  • Country: vn
« Reply #1286 on: November 20, 2022, 06:52:00 am »
Driver from Zadig was installed successful but comp still doesn't see Hantek FEL, just only Unknown device #1 below Usb host tree.
Offline masta_k74
« Reply #1287 on: November 20, 2022, 06:55:23 am »
U24 and U27 are supplied by the 7805 on the main board, which sits at the back of the signal generator directly near the connector where the Dual 8V go to the main board.
So from the dual 8V for the analogue part of the oscilloscope. Not from the +5V for the digital part.
Check the voltages on the 7805 there. I suspect something is wrong there.
Offline nokin
  • Country: vn
« Reply #1288 on: November 20, 2022, 07:06:16 am »
Yes I knew it. I looked at schematic before.
Now I have to de-soldering U24 U27 and check it again.
Volts on every test point is ok. Look like electrical shock from power board when the osc was powered on last time.
Offline masta_k74
« Reply #1289 on: November 20, 2022, 07:16:26 am »
That's exactly what I think.
According to the LMH6702MA (U24 & U27) data sheet, a maximum of ±6.75 is permissible. (Absolute maximum ratings)
With 5V, this is close to its limit for an operational amplifier. I only know of operational amplifiers with a wider voltage range.
I've learned something new again. ;D
« Last Edit: November 20, 2022, 08:10:34 am by masta_k74 »
Online DavidAlfa
« Reply #1290 on: November 20, 2022, 09:07:17 am »
Sometimes it keeps the "unknown device" name, but if it appears correctly (Without any warning sign) it'll be ok.
The following users thanked this post: Russ3000, nokin
Offline AlexGeForce
  • Country: ru
« Reply #1291 on: November 20, 2022, 10:00:43 am »
DavidAlfa,
Tell me, please, have you ever encountered such a defect and is there any way to defeat it?
I have a DSO2D15 oscilloscope right unpacked "out of the box" by pressing the "Help" button after a few seconds it hangs tightly. At least I and another user of Dezmond 2 had this defect
After carefully reading the branch and your posts on Eevblog, I, just in case, made all the necessary backups (both through DSO Flash and through Backup Builder)
In my instance DSO2D15 Software. 1.0.2.0.0.(221028.00)
FW 3205
Board version DSO2D15_V1.7 2021.1.14
« Last Edit: November 20, 2022, 10:08:01 am by AlexGeForce »
Offline Russ3000
  • Country: il
« Reply #1292 on: November 20, 2022, 10:23:39 am »
Offline AlexGeForce
  • Country: ru
« Reply #1293 on: November 20, 2022, 11:15:15 am »
Online DavidAlfa
« Reply #1294 on: November 20, 2022, 11:39:56 am »
DavidAlfa,
- Make a backup with Backup Builder.
- Use Platform-tools to restore a fresh filesystem.
- Restore your dso3kb_CNxxxx.upk backup (Not "FULL").
- Apply latest update.
- Calibrate.
- Done.
Offline nokin
  • Country: vn
« Reply #1295 on: November 20, 2022, 11:41:49 am »
Look like this Hantek for modding and relaxing or angriness (if anyone meet hardware problem as me) not for measuring  |O
Offline nokin
  • Country: vn
« Reply #1296 on: November 21, 2022, 12:28:53 am »
HARD-BRICKED RECOVERY REPORT  :-DD
My scope was alive last night after many effort in hardware and software related recovery
1. Replaced 2 Opamp U24+U27 by AD797 smd (temporary). Scope was booted ok but hung as before.
2. Install Adb fastboot device driver (the most important step after FEL driver)
3. Platform-tools to restore filesystem
4. Update fix and lastest fw
5. Restore backup (any backup upk) but showed red error code -3 (DavidAlfa pls help me... :-DD)
6. Calibrate ok
7. Scope was rescued. Test functions and accuracy ok.
8. Test bandwith, limited ~ 4-5MHz due to AD797's bw but for audio hobby it's still ok.
9. Replace LMH6702MA later if I find any genuine parts.
« Last Edit: November 21, 2022, 12:35:07 am by nokin »
Online DavidAlfa
« Reply #1297 on: November 21, 2022, 03:27:46 am »
Err -3, probably bad UPK, corrupted after removing the drive.
Put UPK files at the root of the usb Drive.
You can also use folders, but can't have spaces or it will fail.
Always use safe USB drive extraction method.
Don't use any Backup if not yours, doesn't make sense.
If not having your own backup, follow the README instructions in Platform-tools to restore your model/serial.
If you have wave generator, calibration will be lost, run calibration tool (In FAQ).
Ensure to read the FAQ!
Offline nokin
  • Country: vn
« Reply #1299 on: November 21, 2022, 09:12:12 am »
I found many replacement on Ali or Shopee but look like fake. Even any single opamp should be worked but bandwidth limited due to opamp hardware spec.
Ad797 now works fine but limited under 5MHz.
