David,
I just ran dso3kb_backup_builder util but it didn't produce any backup files, mem stick was unchanged.
It went through the motions progress bar and hardware re init but zero change to the mem stick is 4gb
Photo of my system info below, only deviation is it has the reboot util installed
2nd try, I just tried it again from mem stick i used to bkup from successfully the other day and bkup didn't work again?
Only change is that the lockup monitor is installed, could it be the issue?
Opps, sitting watching the scope and i just did what looked like a power on up sequence Hantek logo full initialization etc.
Didn't look like the locked reboot i had the other day, this was like a power on sequence, any ideas?
Update, removed reboot monitor and backup worked
Final 1145 update installed 0630 then 0705, reboot and recal. Scope for 5 min and locked up, install lockup monitor and testing see 2nd photo 5573.
ian
