I finally had the chance to test this new oscilloscope and I can say I am very pleased so far. It's clearly an entry level scope but it has all the basic functions that most users would need.
It's very usable and I found less bugs in the FW than I would have expected from such a new product from Hantek and the ones I reported, Hantek promptly fixed. Although, I didn't have the time to test all functions, specially the serial decode. Has anyone used this? Does it work well?
The hardware is simple and the board has a lot less components than other models from Hantek, but it does the job. As already pointed by another user, the UI is not the most responsible but it's tolerable, specially considering the price range of this device. Apparently, Hantek is trying to use as many Chinese made ICs as possible. The ADC's marking are completely erased and the main processor is a Lemontree FPGA (
![Huh? ???](https://www.eevblog.com/forum/Smileys/default/huh.gif)
The DAC for the AWG had also its marking removed, but I believe it could be the Chinese
3PD5651E. This is the same IC used in their handheld scopes (HT2000) and it's a 10bit DAC. That would explain why they are trying to hide it's specs. It's claimed the awg has a 12bit resolution, but the DAC is only 10bits. They must use some software trickery to increase the resolution. It could be the same reason why the ADC's marks were erased. Maybe they are using a cheaper and slower DAC and overclocking it to get the claimed 1GSa/s specs. Hantek made that with the HT2000 as well.
The color display is very nice but the view angle is a little poor. The big fonts make it easy to read the information on the screen. The push buttons are good enough but the rotary encoders fells cheap and a bit dicky, time and use will tell how reliable they are.
All in all, it's a fairly decent oscilloscope, considering that Hantek advertise it as "cost-effective economy" and some compromised had to be made.
