Author Topic: New Hantek DSO2X1X models?  (Read 454418 times)
Offline cmaass
Re: New Hantek DSO2X1X models?
« Reply #25 on: December 20, 2020, 04:47:54 pm »
Hi  jobitjoseph1
So it seems yours is later than mine.
Could you please upload it here so that I also can have the latest version.
When I do the platform tools low level it also shows on mine as 20201127.01 and mine is 20201118.01, so it must be integrated into the platform tools.
I just want to make sure I have the latest update on a stick.
Thanks.
Offline cmaass
« Reply #26 on: December 20, 2020, 04:53:42 pm »
Just make sure to pack it to a .zip or .rar.
They do not aloud .upk for uploading.
Offline jobitjoseph1
  • Country: in
« Reply #27 on: December 21, 2020, 11:44:54 am »
Hi  jobitjoseph1
Thanks.
Hi, frequency and time period measurement fixed with new firmware . Please find it in the attachment.
The following users thanked this post: cmaass
Offline cmaass
« Reply #28 on: December 21, 2020, 09:31:56 pm »
I found a bug on this update 20201207.01 after installing it.
While measuring a signal from the AWG. if I switch the scope to autorange, when I increase the frequency from the Gen, the scope freeze.
I then rebooted and after this the Auto Set did not work anymore.
I then went back to autorange, pressed auto set again and this time it worked.
Another thing that bothers me, if there is an AC signal present on a DC level and I want to measure just the AC signal, when I switch the input coupling to AC, as soon as I press Auto Set, it jumps back to DC and measure the DC value.
Its impossible to measure a small  AC waveform, such as an audio signal, which rides on DC level by using Auto Set.
Auto Set should not switch the Input Coupling. That is why I tried autorange to see if I could do it with that.
« Last Edit: December 22, 2020, 03:42:26 pm by cmaass »
Offline upsss
« Reply #29 on: December 21, 2020, 09:49:56 pm »
In a way I am glad that they delayed shipping my scope, the latest shipping date is now December 28.  Hopefully by then they will fix all these stupid bugs, although I am not holding my breath.
Offline PerepandelTopic starter
« Reply #30 on: December 25, 2020, 03:31:42 pm »
You should write them informing of this, @cmaass
Offline upsss
« Reply #31 on: December 26, 2020, 05:09:00 pm »
Banggood shipment of the DSO2D10 was postponed again, now to January 4.
Offline cmaass
« Reply #32 on: December 27, 2020, 06:47:43 pm »
I did inform Hantek Support of the Bug.
Offline cmaass
« Reply #33 on: December 29, 2020, 04:49:01 pm »
After reporting the Bug to Hantek they've sent me the latest update. Download beneath.
I will try to upload the platform tools to filemail again.
It is a very large file that is why it cannot be posted on this forum.
Will post the link later on.
  • Country: in
« Reply #34 on: December 29, 2020, 05:35:40 pm »
the bug fixed with this update?
Offline cmaass
« Reply #35 on: December 29, 2020, 06:02:31 pm »
They said so yes, but I still have to check if it is fixed.
Did not load the update yet.
The following users thanked this post: jobitjoseph1
Offline cmaass
« Reply #36 on: December 29, 2020, 07:15:27 pm »
OK, I uploaded the new firmware. Firmware is now b000.
I now even found more bugs on the Autorange.
The Scope freeze under various circumstances which is not consistent, it changes.
Sometimes it freeze when I switch on the AWG, sometimes when I change the AWG frequency, etc. etc.
Also the number of cycles that it displays is sometime up to ten, sometimes only five and so on.
As soon as I want too use Autorange on single period it sometimes freeze.
The input still switches to DC when pressing Auto Set.
They told me it is supposed to do that, which I cannot believe.
It is stupid,it should not.
Below is a new  link to download the platform tools.
It is only available for 7 days.
Just follow the instructions in the readme_English.docx file in the platform tools folder.
I just want to add, after I used the platform tools whenever I press the System Info function key in the Utility Menu it no longer shows the Model number, Serial number and Hardware info, those are undefined.
It only shows the Software and Firmware numbers.
What I found found was that after I loaded the Android driver with sunxi-fel uboot images/uboot_fastboot.bin ,  when I ran the cmds.bat file , when the scope rebooted it freezed,
I then switched the scope off and on again by pressing the button underneath while switching it on. (I used a matchstick to press the button, that way you cannot short out anything.)
After that I ran the cmds.bat file straight away whithout using sunxi-fel, since the Android file is now already present. It then booted without any problems.
If it shows as a Winusb device under Device Manager with the driver info as you saw in the Zadig-2.5 utility, you can just use the cmds.bat file whenever the scope freezes during rebooting and if you are unable to reload the update file. Although it only happened to me that one time.
The Phoenixsuite_CN.msi is in Chinese, so if it does not install just try again by pressing other buttons ;D. The first time that I used the zadig_2,5 utility the scope came up as an unknown device and I had to re-install Phoenixsuite again and reloaded the win driver with zadig before it showed up correctly.
Here is the link to download the platform tools.: https://fil.email/OQeqFVAX
Best of luck!
Disclaimer: You use these at your own risk, if it does nor work, don't blame me, although according to them one cannot brick the  Allwinner Controller. I don't know.
If anyone can figure out how to get the system info back again please let us know.
  • Country: in
« Reply #37 on: January 01, 2021, 07:03:27 am »
Best of luck!
For me it never freezed. But with AWG on auto set doesn't works properly ( works fine with square wave out) but with any other type of wave form auto set is not working properly, especially at lower frequencies. With higher frequencies ,ie MHz range it's works.
Offline cmaass
« Reply #38 on: January 01, 2021, 06:32:40 pm »
Hi  jobitjoseph1
Do you mean you did the platform tools. If so did did you run cmds.bat straight after loading the Android driver with sunxi-fel.
If I do that my scope,when it reboots, get as far as the 2nd Hantek logo then it does not boot any farther.
I have to restart it with pressing the button underneath and then run cmds.bat directly.
Is  your System Info still displaying the model no etc.?
Mine displays everything as  undefined, except for the software and firmware versions.
I still have a lot of problems with my Autorange setting.
  • Country: in
« Reply #39 on: January 01, 2021, 07:01:51 pm »
Hi  jobitjoseph1
Hi cmaas
     I was talking about the dso3kb_20201221 update. The bugs you have mentioned .And after posting the previous reply, my scope just frozen when I pressed single seq button. As you mentioned earlier this build has more bugs than the previous one , the bugs aren't even consistent
Offline upsss
« Reply #40 on: January 03, 2021, 06:43:48 pm »
Banggood shipment of the DSO2D10 was postponed again, now to January 12.  This is a JOKE, already more than a month pass their original shipping date!  I suspect it's Hantek problem not Banggood as they are trying to fix all their bugs.
Offline cmaass
« Reply #41 on: January 03, 2021, 07:04:14 pm »
Exactly jobitjoseph1, I find new and different bugs every time I try to use the scope.
If you guys get any bugs you can report it to support@hantek,com, they send it to wangshuang@hantek.com. This person will definitely get back to you and then you can email directly to him. but please send first to support.
He is very helpfull, it's him that has sent me all the software and updates.
  • Country: in
« Reply #42 on: January 08, 2021, 06:05:04 pm »
Anybody received any new update?
Offline cmaass
« Reply #43 on: January 08, 2021, 08:30:05 pm »
No, no updates.
I saw that eventually Hantek is now displaying the DSO2000 series on their website, but the only download is a user manual so far, no firmware updates or any other software.
Offline tinhead
« Reply #44 on: January 09, 2021, 10:09:28 pm »
ahh, another Hantek to hack. I don't have it yet (still having the 10yrs old Tekway/Hantek, frack that, it works still) and probably will not buy it now (as my Siglent works better), but maybe will take a look on firmware.
To decrypt firmware use dso3000c as passpharse, e.g.
cmd.exe /C echo dso3000c| gpg --batch --passphrase-fd 0 --output decrypted.tar.gz -d dso3kb_20201207.upk
@cmaass can you upload the platform tools once again somewhere?
The following users thanked this post: Mark5
Offline tinhead
« Reply #45 on: January 09, 2021, 10:25:48 pm »
looks very similar to what i saw all the years on hantek, one can easily create own update file to dump everything to usb:
- create your own do_update.sh
- leave the "special" file in update, the firmware updater checks for it and let you do whatever you wish as long the file is there
- leave the manifes.xml as is, this one is new thing after Hantek changed their ui things, they even didn't edited it (it shows still dso4000 series)
- finally edit the upend file, to have only these files (in root of fw update file) and dirs you really have
- encrypt it with gpg and the dso3000c passpharse, tar/tar/gz and you're done with custom firmware update
Offline tinhead
« Reply #46 on: January 09, 2021, 10:31:50 pm »
yeah, probably something missing, in the bin file there is "undefined".
My proposal, make firmware update which will dump everything, and let someone else to dump his/her DSO, so you can compare to yours.
Offline cmaass
« Reply #47 on: January 11, 2021, 06:59:46 pm »
@tinhead
Right, will upload the platform tools once again to filemail
Will post the link as soon as it is finished.
Offline cmaass
« Reply #48 on: January 11, 2021, 09:42:11 pm »
OK, here is the download link for the Platform Tools.
It's only valid for seven days.
Remember to read the readme_English.doc file how to use.
Use at own Risk.
https://fil.email/b1bkxGX2
Offline upsss
« Reply #49 on: January 23, 2021, 05:18:40 pm »
Either Banggood or Hantek, probably the latter have major problems shipping these new Hantek DSO2X1X scopes.  I ordered mine on December 8 from Banggood and they have pushed back the shipping date more than a dozens of times, now it is "scheduled" for February 4.   I am NOT holding my breath for this shipment date either.  Banggood also raised slightly the prices of these scopes since December.
It looks like Hantek rushed the initial shipments of these scope and now they have stooped it completely.  I believe they are trying to fix all their problems before resuming shipments.
« Last Edit: January 23, 2021, 05:22:39 pm by upsss »
