I don't know what to think. Hantek has been selling it for 6 months.
The development might have took months or even years (F1C200s came out in 2017).
But they released a big pile of **** that couldn't even be called "beta".
Maybe alpha-1. Which means it boots and does something.
And then very slowly start fixing things. I just hate the sell-now, maybe-fix-later thing.
Decided to flash sw 20210517 and stop the hacking for a while.
It seems prety stable. I've hit the buttons and knobs like there was no tomorrow, no lockups for now.
Undefined settings doesn't seem to cause any trouble. Signal gen works too.
Did they hack themselves? It's "undefined" the master hack that enables everything?
![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
I think someone complained about the signal gen not going below 100Hz.
Well, at least in 20210517 version, it goes down to 0.1Hz.
However Fmax is different for each wave type:
- Sine: 25MHz
- Square: 10MHz
- Ramp: 1MHz
- Exp: 5MHz
- DC mode works.(Previously greyed out). Amplitude is disabled, and you adjust offset.
But the offset is way off!
- 1V=1.2
- 2V=2.4
- 3V=3.6
- 3.5V=3.9
It happens in all gen modes.
Calibration: In DC and AC modes it seems ok. But setting coupling ton GND the signal goes negative, 1/2 division below ref.
Trigger works pretty nice, but not perfect. Ex. 1Vpp test signal:
In 50mV/div or more it shows great.
In 20mV/div and below it moves like crazy. Clearly trigger not doing ok.
The decoders work really bad. Most of the time they don't find anything, or they're wrong.
A big issue there: Memory depth is limited to 4K in when decoder is enabled. So you won't get more than few bytes...
Zooming causes a line to be drawn over the decoded data.
PC software: I installed the drivers, windows recognized the device as "USB Test and Measurement Device (IVI)".
But neither DigitalScope or WaveEditor were able to connect, complaining with message "The device is not connected".
Edit: After reinstalling the driver with the scope already connected, it worked.
The custom waveforms can be set up to 25MHz too.
HR mode looks a lot better!
![](https://www.eevblog.com/forum/testgear/new-hantek-dso2x1x-models/?action=dlattach;attach=1224189)
