OK, I uploaded the new firmware. Firmware is now b000.
I now even found more bugs on the Autorange.
The Scope freeze under various circumstances which is not consistent, it changes.
Sometimes it freeze when I switch on the AWG, sometimes when I change the AWG frequency, etc. etc.
Also the number of cycles that it displays is sometime up to ten, sometimes only five and so on.
As soon as I want too use Autorange on single period it sometimes freeze.
The input still switches to DC when pressing Auto Set.
They told me it is supposed to do that, which I cannot believe.
It is stupid,it should not.
Below is a new link to download the platform tools.
It is only available for 7 days.
Just follow the instructions in the readme_English.docx file in the platform tools folder.
I just want to add, after I used the platform tools whenever I press the System Info function key in the Utility Menu it no longer shows the Model number, Serial number and Hardware info, those are undefined.
It only shows the Software and Firmware numbers.
What I found found was that after I loaded the Android driver with sunxi-fel uboot images/uboot_fastboot.bin , when I ran the cmds.bat file , when the scope rebooted it freezed,
I then switched the scope off and on again by pressing the button underneath while switching it on. (I used a matchstick to press the button, that way you cannot short out anything.)
After that I ran the cmds.bat file straight away whithout using sunxi-fel, since the Android file is now already present. It then booted without any problems.
If it shows as a Winusb device under Device Manager with the driver info as you saw in the Zadig-2.5 utility, you can just use the cmds.bat file whenever the scope freezes during rebooting and if you are unable to reload the update file. Although it only happened to me that one time.
The Phoenixsuite_CN.msi is in Chinese, so if it does not install just try again by pressing other buttons
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
. The first time that I used the zadig_2,5 utility the scope came up as an unknown device and I had to re-install Phoenixsuite again and reloaded the win driver with zadig before it showed up correctly.
Here is the link to download the platform tools.:
https://fil.email/OQeqFVAXBest of luck!
Disclaimer:
You use these at your own risk, if it does nor work, don't blame me, although according to them one cannot brick the Allwinner Controller. I don't know.
If anyone can figure out how to get the system info back again please let us know.
