Author Topic: New Hantek DSO2X1X models?  (Read 454734 times)
Offline DavidAlfa
Re: New Hantek DSO2X1X models?
« Reply #1575 on: September 09, 2023, 05:40:02 pm »
You're right. Then there're few options left.
- Corrupted fpga FW file? I don't think so, the buttons wouldn't work either.
- Corrupted filesystem? Maybe... still, rare that only the buttons work.
 (Both would be fixed with platform-tools)
- Defective chips? Still rare, maybe a bad soldering joint.
The encoders common wires are Scan_Data_4 &  Scan_Data_6.
Maybe one of these are bad, or any of the diodes is shorted.
The Scan_Lines are also used for the buttons, so they would also fail if bad.
« Last Edit: September 09, 2023, 05:47:59 pm by DavidAlfa »
The following users thanked this post: morgan_flint
Offline morgan_flint
« Reply #1576 on: September 09, 2023, 05:48:22 pm »
Just read your post, that came up while I was editing mine  :'(
I had checked for continuity between diodes and U2, but I didn't check for shorts on the diodes. Will dismount it again and check.
EDIT: Done, all the diodes are OK. Also checked the connections between U2 and U1, also OK. Tried also some more cleaning and heating around U1 and U2 with hot air. No luck. Time for platform tools
EDIT2: Updated to SW 1.0.2.0.0 (221028.00) FW 3205 with Platform Tools (it was 1.0.1.1.0 (20210726.00) 3202). No luck. Must be a hardware failure (probably U2 or, maybe, U1). I will retouch all solders before trying anything else.
Any other ideas?
« Last Edit: September 09, 2023, 06:35:14 pm by morgan_flint »
Offline DavidAlfa
« Reply #1577 on: September 09, 2023, 06:38:00 pm »
Is R109 OK? It's the only thing powering the keypad matrix.
« Reply #1578 on: September 10, 2023, 09:05:18 am »
Yes, I also checked R109. Although it is common with the rest of the keys, I suspected it could be also the problem because of the forward drop in the diodes (supposing there was a weaker pullup also in the FPGA). But no, it's OK.
Although I had already checked them with the multimeter, I also resoldered relevant pins of U2 (1, 2, 9, 10, 11) and U1 (3, 4, 5), but no luck.
If it's not a SW or FW problem, I can only suspect bad U2, more remotely, bad U1, or, even more strange, a failure in the FPGA section in charge of reading the keyboard.
If I had a longer ribbon cable, I could also try some "live" measurements in the user interface board, but I don't have it.
Unfortunately, without the encoders, the scope is practically useless, but maybe I can still use it with the Keysight application
« Last Edit: September 10, 2023, 09:12:05 am by morgan_flint »
Offline DavidAlfa
« Reply #1579 on: September 10, 2023, 10:49:27 am »
Do you have access to the serial port? It would be interesting to see the kernel messages.
But you need flash the oldest platform-tools version, the keypad kmod (/dso/etc/fpga_i2c_kb.ko) debugging output was silenced in newer versions.
On rotation you should see a lot of messages like:
[   22.793724] Get irq key
[   22.818725] Get irq key
« Reply #1580 on: September 10, 2023, 11:16:30 am »
Yes, I have access to serial port. As I said before, I updated to the latest version SW 1.0.2.0.0 (221028.00) FW 3205 to see if that solved the problem but, seeing that it didn't, I went back to SW 1.0.1.1.0 (20210726.00) FW 3202, and the problem persists.
With the old SW&FW, I can't see any "irq" messages in the console. I'm attaching the console's output after a reboot and after pressing several keys and rotating knobs. Also checked that /dso/etc/fpga_i2c_kb.ko exists, but I don't know if I have to do something else to get the "irq" messages
EDIT:
I opened a ticket in Banggood; I don't expect anything as I bought it on 2022-03-20, more than a year ago, but you never know if you don't try.. I'm suggesting them to send me a replacement for the interface board, that should be cheap for them, and replace it by myself. Let's see what happens...
Also checked at https://www.eediscuss.com/forum.php that problems with knobs and keyboard are frequent
« Last Edit: September 10, 2023, 11:22:11 am by morgan_flint »
Offline DavidAlfa
« Reply #1581 on: September 10, 2023, 11:58:49 am »
Nah, try the oldest build, I know it's FW3000, it won't damage anything.
The kernel module in FW3202 version is already silent.
Alternatively you can manually replace the module with the attached ones and rebooting afterwards to take effect:
cp /mnt/udisk/fpga_i2c_kb_verbose.ko /dso/etc/
# Or
cp /mnt/udisk/fpga_i2c_kb_silent.ko /dso/etc/
reboot
Any key/encoder activity is shown:
[  123.838713] Get irq key                                        <---------- Encoder rotation
[  124.113703] Get irq key
[  124.138710] Get irq key
[  124.163720] Get irq key
[  124.188729] Get irq key
[  124.213696] Get irq key
[  124.238704] Get irq key                                             <---------- Button press
[  125.617587] dso keyboard: key (code 0x1) pressed.,0
[  125.738713] Get irq key                                           <---------- Button Release
[  125.742694] dso keyboard: key (code 0x1) released.,0
Code 0x1 is F0 button.
« Last Edit: September 10, 2023, 12:03:39 pm by DavidAlfa »
« Reply #1582 on: September 10, 2023, 12:45:15 pm »
Done!
[  136.417041] Get irq key
[  136.433047] dso keyboard: key (code 0xe) released.,13
[  149.642025] Get irq key
[  149.658439] dso keyboard: key (code 0x7) pressed.,6
[  149.842016] Get irq key
[  149.858236] dso keyboard: key (code 0x7) released.,6
[  156.892013] Get irq key
[  156.908293] dso keyboard: key (code 0x3) pressed.,2
util_thread_pause:thread 0xa8fc70 is paused
[  157.004948] fpga_ctl_kbd_event:17, 3, 0, 50
[  157.009204] cnt =1,80,124
[  157.022758] cnt =0,80,124
[  157.026935] fpga_ctl_kbd_event:17, 5, 0, 40
[  157.033041] fpga_ctl_kbd_event:17, 7, 0, 0
[  157.042905] Get irq key
[fpga_dds__set_dds_light] 0
[  157.058569] dso keyboard: key (code 0x3) released.,2
[  157.082690] cnt =1,64,124
[  157.102674] cnt =1,0,124
[  157.122654] cnt =0,0,124
ia_self_test_on_key_up:65471
[  159.617033] Get irq key
[  159.632270] dso keyboard: key (code 0x12) pressed.,17
[  159.767034] Get irq key
[  159.782249] dso keyboard: key (code 0x12) released.,17
ia_self_test_on_key_up:75
[  160.567032] Get irq key
[  160.582264] dso keyboard: key (code 0xa) pressed.,9
[  160.692035] Get irq key
[  160.707332] dso keyboard: key (code 0xa) released.,9
[  160.712348] dso keyboard: key (code 0xa) pressed.,9
[  160.717354] dso keyboard: key (code 0xa) released.,9
ia_self_test_on_key_up:67
[  162.567031] Get irq key
[  239.767014] Get irq key
[  239.782266] dso keyboard: key (code 0x20) pressed.,31
[  239.892018] Get irq key
[  239.907317] dso keyboard: key (code 0x20) released.,31
ia_self_test_on_key_up:88
[  249.142022] Get irq key
[  249.167045] Get irq key
[  249.192009] Get irq key
[  249.217037] Get irq key
Apparently, the same results as you: it responds to encoder rotation, but they don't work doing what they're supposed to do!
I understand this discards any hardware failure, at least at the user interface PCB
Completely clueless now!
EDIT: sometimes I stop getting "Get irq key" on rotating the knobs. But no response on the screen even when the "Get irq key" appears
« Last Edit: September 10, 2023, 12:59:57 pm by morgan_flint »
Offline DavidAlfa
« Reply #1583 on: September 10, 2023, 01:31:33 pm »
Rotate V0 knob while not in any menu, so the dso app doesn't show its stuff.
You should get plenty of irq messages in a single rotation.
Do you have any signal analyzer? Would be interesting to see what's going on at the encoder pins.
I'd replace the 4051s and the 4066, they're cheap so you won't lose anything trying.
« Last Edit: September 10, 2023, 01:35:03 pm by DavidAlfa »
« Reply #1584 on: September 10, 2023, 03:58:39 pm »
That's what I get, not only with V0, but with all the knobs, although sometimes there are some interruptions and lags.
Quote from: DavidAlfa
No, unfortunately, I don't (although planning to get one of those cheap USB login analyzers one of these days...). I should also need a longer ribbon cable to be able to access the user interface PCB with the rest of the scope connected.
Yes, I think I'll try that, but considering the HW detects the knobs' movement, as stated by the IRQ messages, I don't have much confidence that it'd solve the problem, but it's worth a try.
Just a last crazy elucubration: when the rear USB is connected to the PC and Keysight's application is running, the front panel keys are locked... ¿Could it be something is blocking the response to the knobs, although nothing is connected? Would be very strange, as buttons should also lock, but almost all the sensible possibilities have come to an end
« Last Edit: September 10, 2023, 04:04:14 pm by morgan_flint »
Offline DavidAlfa
« Reply #1585 on: September 10, 2023, 04:08:43 pm »
I forgot something: You get the IRQ on *any* change, even if the knob didn't made a full quadrature cycle.
It seems everything is processed in software, the fpga just sends raw data when something changes.
So imagine the encoder contacts "A" and "B"... Only "A" might be toggling, and "B" stuck high/low, nothing would happen but you will get the IRQ messages as well.
This is while rotating the Time/Div control.
At first I'm making full steps, but then I'm making half steps, backwards and forwards, so it never settles into the next step.
Still, you get plenty of IRQs.
[   94.585066] Get irq key
[   94.610065] Get irq key
dso_acq_control:1:store_depth 4000, extra_len 64,acq_all_nm_for_read 4064,acq_dot_nm_of_timerange 80,sample_rate = 1000000000.000000
[   95.285081] Get irq key
[   95.310090] Get irq key
dso_acq_control:1:store_depth 4000, extra_len 64,acq_all_nm_for_read 4064,acq_dot_nm_of_timerange 160,sample_rate = 1000000000.000000
[   96.110066] Get irq key
[   96.135080] Get irq key
dso_acq_control:1:store_depth 4000, extra_len 64,acq_all_nm_for_read 4064,acq_dot_nm_of_timerange 320,sample_rate = 1000000000.000000
[   96.985074] Get irq key
[   97.010073] Get irq key
dso_acq_control:1:store_depth 4000, extra_len 64,acq_all_nm_for_read 4064,acq_dot_nm_of_timerange 800,sample_rate = 1000000000.000000
[  101.035063] Get irq key
[  101.310079] Get irq key
[  101.935058] Get irq key
[  101.985166] Get irq key
[  102.060081] Get irq key
[  102.110083] Get irq key
[  102.410074] Get irq key
[  102.560081] Get irq key
[  102.660067] Get irq key
[  102.735065] Get irq key
[  102.860078] Get irq key
[  102.935082] Get irq key
[  103.160093] Get irq key
[  103.310069] Get irq key
[  103.335062] Get irq key
[  103.410078] Get irq key
[  103.485066] Get irq key
[  103.510078] Get irq key
[  103.635070] Get irq key
[  103.760065] Get irq key
[  103.835067] Get irq key
[  103.860062] Get irq key
Take any of the stepping encoders, and slighly turn them to right or left, about 1/4 of the step, much less than it would need to make the "click".
Do you notice one side behaving differently? I one side needs more than the other, then it's likely to be a bad common signal.
Try soldering two wires to any encoder pins, then randomly touch ground with one at a time. Or just shorting them with tweezers or whatever.
I guess one of them won't make the IRQs!
« Last Edit: September 10, 2023, 04:21:09 pm by DavidAlfa »
« Reply #1586 on: September 10, 2023, 04:15:38 pm »
It's a good guess, although not all the encoders are going to get one contact stuck at the same time. But the symptoms would also be the same if one of the signals Scan_Data_4 or Scan_Data_6 (not both at the same time) had gone nuts!
Time to look for an HC4051!! Thanks!!
Offline DavidAlfa
« Reply #1587 on: September 10, 2023, 04:22:05 pm »
I don't mean the encoder is stuck, but one of 4051s!
« Reply #1588 on: September 10, 2023, 04:38:06 pm »
Ah, OK, I didn't understand it well. Sorry!
Most probably, U2, as it is the one that has two signals exclusively for the encoders, so it's the first one to be changed, but I'll buy more than one, just in case.
« Reply #1589 on: September 11, 2023, 04:50:01 pm »
I tried this and, as you guessed, one of them (the one that corresponds to Scan_Data_6) doesn't make IRQs.
It seems clear that channel 6 of the analog multiplexer U2 is not working.
I also checked that pulling down the Key_Scan_Data generates lots of IRQs, with lots of random key detections  ;D
I also made another desperate attempt: shorting out pins 2 and 4 of U2, in the hope that channel 7 (unused, as Scan_Data_7 doesn't exist) would work and the software would "understand". But no luck. Replacing U2 is now the only hope...
Offline DavidAlfa
« Reply #1590 on: September 11, 2023, 05:03:05 pm »
You got it! Should be it. What else if not?
Damaged FPGA? Strange, but go figure.
Maybe they called them "LemonTrees" because they didn't pass QA and GoWin didn't want to its name there.
Offline Joemega
  • Country: hu
« Reply #1591 on: September 12, 2023, 11:23:47 am »
...sorry for my bad english...
Maybe, your problem is the same like mine DSO2D10 after a few month: suddenly shortcut in one of rotary encoder case (GND) to the inner encoder PCB.
It's blocking the data lines.
Mine repair was simple: teardown the encoder case, a little tape to isolate.
Search this video in YouTube: "Hantek DSO5202P: Knobs/Encoders Not Working Repair"
Maybe helping you...
The following users thanked this post: morgan_flint, RAPo, dirtmover
Offline IonutL
« Reply #1592 on: September 13, 2023, 02:44:24 pm »
Hello experts!
I got a DSO2D15 and I started making backups. First I used Backup_Builder so now I have all the files it produced. Then I made a safety backup with Dsoflash and it produced the 135168kB file. Then at the first power cycle the problems started. Serial and Hardware in system information show "undefined", so i tried to update them using the file "dso3kb_CN2318029043950_Model.upk", but I got an error:
Updated failed! Error code is -2
I tried also the USB fix update, the latest update from Hantek site, the full update I have got from Backup_Builder, even do_other_update without any script (just to test if it runs), all throw immediately the same error:
I also tried the "Default setup" key, nothing changed.
Also tried in the Keysight Connection Expert console
PRIVate:SET:PCB "003.002.001.000.000.000.000.001"
error:
 ! VI_ERROR_TMO: A timeout occurred
Visa ErrorCode: 0xBFFF0015 (-1073807339)
and
PRIVate:SET:SERIal CN2318029043950
however, the command:
PRIVate:FACTORY:RESET
reboots the scope, but returns error
-> PRIVate:FACTORY:RESET
 ! VI_ERROR_IO: I/O error
Visa ErrorCode: 0xBFFF003E (-1073807298)
What is weird is that after every power cycle the scope seems to forget some of the settings (if I disable the sound, it comes back at next power on); or if I save the settings in the internal memory it says it was done ok, but when I recall them it say "Recall failed".
Before making backups the system info showed (it looks to me that there are the latest versions of software and firmware):
Model: DSO2D15
Serial CN2318029043950
Software 1.0.3.0.0(230327.00)
Hardware 003.002.001.000.000.000.000.001
Firmware 3205
So my question is: is it any way to get back the update functionality? and as a bonus to set the serial and hardware fields?
Best regards,
Ionut
Offline DavidAlfa
« Reply #1593 on: September 13, 2023, 02:49:26 pm »
That's really weird. Try platform-tools then restoring your backupbuilder backup.
Or restoring the entire dsoflash backup.
« Last Edit: September 13, 2023, 02:57:03 pm by DavidAlfa »
Offline IonutL
« Reply #1594 on: September 13, 2023, 03:00:06 pm »
It doesn't work. Platform-tools ends in error:
FLASH FAILED!
ERASE PARTITIONS...
Erasing 'boot'                                     OKAY [  0.045s]
Finished. Total time: 0.053s
Erasing 'cache'                                    OKAY [  0.077s]
Finished. Total time: 0.091s
Erasing 'dtb'                                      OKAY [  0.034s]
Finished. Total time: 0.048s
Erasing 'kernel'                                   OKAY [  0.073s]
Finished. Total time: 0.082s
Erasing 'rootfs'                                   FAILED (remote: 'failed erasing from device')
fastboot: error: Command failed
Failed to erase the memory!
Offline DavidAlfa
« Reply #1595 on: September 13, 2023, 03:05:15 pm »
No damn idea! Post the complete log.
Offline IonutL
« Reply #1596 on: September 13, 2023, 03:47:47 pm »
Not easy because of the cls in the batch:
FLASH PARTITIONS...
Selected:    2022.10.28_fpga_3205
< waiting for any device >
Sending 'boot' (202 KB)                            OKAY [  0.022s]
Writing 'boot'                                     OKAY [  0.137s]
Finished. Total time: 0.177s
Sending 'logo' (750 KB)                            OKAY [  0.063s]
Writing 'logo'                                     OKAY [  0.606s]
Finished. Total time: 1.892s
Sending 'dtb' (11 KB)                              OKAY [  0.008s]
Writing 'dtb'                                      OKAY [  0.039s]
Finished. Total time: 0.086s
Sending 'cache' (1612 KB)                          OKAY [  0.109s]
Writing 'cache'                                    OKAY [  0.710s]
Finished. Total time: 0.846s
Sending 'kernel' (2999 KB)                         OKAY [  0.197s]
Writing 'kernel'                                   OKAY [  1.468s]
Finished. Total time: 1.682s
Sending 'rootfssize' (0 KB)                        OKAY [  0.007s]
Writing 'rootfssize'                               FAILED (remote: 'ubi erase failed')
FLASH FAILED!
ERASE PARTITIONS...
Finished. Total time: 0.051s
Finished. Total time: 0.085s
Finished. Total time: 0.050s
Erasing 'kernel'                                   OKAY [  0.075s]
Press any key to continue . . .
Offline IonutL
« Reply #1597 on: September 13, 2023, 03:51:07 pm »
And I have to add that a normal boot leads to a blank screen, now it's totally bricked...
Offline DavidAlfa
« Reply #1598 on: September 13, 2023, 03:53:10 pm »
For whatever reason the nand can't be written to!
Of course, if new data can't be written, it won't boot.
What does "dsoflash erase" do?
Also try erasing the entire flash with xfel.
Only boot in fel mode, then:
xfel spinand
if detected
xfel spinand erase 0x0 0x8000000
But it's basically the same.
« Last Edit: September 13, 2023, 03:57:55 pm by DavidAlfa »
Offline IonutL
« Reply #1599 on: September 13, 2023, 04:23:56 pm »
xfel spinand
Found spi nand flash 'W25N01GV' with 134217728 bytes
100% [================================================] 128.000 MB, 13.645 MB/s        00
dsoflash erase did erase it ok also.
But platform-tools still fails with the same errors as before.
