Hello,
So I've been playing around with this device for a few days, and even if it certainly has its flaws, I quite like it as a cheap device I can move around.
The single shot bug was a deal-breaker for me, so I took a look at the firmware in Ghidra in an attempt to fix it.
First, I found a few features that missing from the manual :
- There is a scope calibration function (DC offset nulling ?) engaged by long pressing "AUTO" in scope mode.
- Long pressing the center button in scope mode moves the traces to their default position.
- Long pressing CH1 and CH2 in multimeter modes enter some calibration mode (didnt try it, I dont want to mess the calibration on mine)
Then I was able to locate the issue with the single mode trigger :
Where I was expecting some sort of indexing issue, I found out they actively zero the sampling buffer before the trigger point !! (see attached picture)
Not sure what they had in mind when they wrote that, but I was able to make the code jump over that "feature" with a single byte change in the firmware.
I also changed the version string from 2.0.2 to P2.0.3 to make it clear what firmware the device is running
You'll find the patched firmware attached to this message, along with 2 screenshots showing the change of behavior from Fnirsi original firmware (2.0.2) to my patched version (P2.0.3)
TRY IT AT YOUR OWN RISK. I am not responsible for any bricked device.
It still doesnt make the single trigger mode perfect, as it samples a relatively low percentage of the time, so it easily misses the trigger point.
I might be able to prevent it to trigger entirely if the trigger point is not in the sampling buffer, but I feel it might look misleading.
To install the new firmware, hold the MENU button before pressing the POWER button (bootloader mode), then plug the device to a PC, and drop the firmware in the newly found USB disk.
If anything goes wrong, you can insert a pin in the hole on the side to reset it, re-enter the bootloader mode, and flash the original firmware back.
Feel free to leave any feedback !
