Author Topic: New handheld scope+DMM, BSIDE 01, 1ch, 10MHz/48MSps (Nov 2023)  (Read 3819 times)
Offline tunkTopic starter
  • Country: no
« on: November 16, 2023, 05:53:30 pm »
Isn't there enough of these:
- 1ch, 10MHz bandwith, 48MSps
- 100ns/div - 20s/div
- 200mV/div - 100V/div
- AC, DC
- sampling depth 64kB
- 2.8" display, portrait mode
- size 187x74x40mm
- 6000 count DMM
- from around $55-60: https://www.aliexpress.com/item/1005006164727405.html
« Last Edit: November 16, 2023, 05:57:22 pm by tunk »
Offline Aldo22
Re: New handheld scope+DMM, BSIDE 01, 1ch, 10MHz/48MSps (Nov 2023)
« Reply #1 on: November 17, 2023, 01:37:47 pm »
Here's a video:
Offline Kean
    • Kean Electronics
« Reply #2 on: December 17, 2023, 10:20:50 am »
I kind of like the look of this BSIDE O1 handheld "scope".  It would be nice if it was a bit smaller, but it is only slightly longer than my BM235, and a little narrower.
I like that it lets me use my preferred Pomona multimeter probes (TBC).  More importantly it clearly shows the MIN & MAX value of a measurement, so I can see if a value is not steady and switch to scope mode to check for noise or oscillation.  I am not always at one of my benches with a scope handy, nor do I want to wait for a scope to boot or rearrange things to connect a scope probe.
I have a FNIRSI 5012H pocket scope but never really liked using it.  I am mostly interested in quick low voltage DC measurements, and checking for signals less than 1MHz.  For this I prefer just the DMM probes or other banana plug test leads.  If I need a scope it will be for precise multichannel measurements or decoding, and I will use my MSO5074 or RTB2004.
I was able to pick up a BSIDEO1 today on AliExpress for AU$60 (about US$40) including shipping and tax.  Thankfully the seller had red ones, as I think the green is ugly.  I know BSIDE often sell their products in multiple colours.
Offline Kean
    • Kean Electronics
« Reply #3 on: December 28, 2023, 02:18:49 am »
I got my BSIDE O1 unit today.  Just had a quick play with it so far, but I like it.
It is not much bigger than the BM235 which is quite a nice mid-sized meter.  The supplied probes are not too chunky (I like the small Pomona ones), and have sharp tips and very soft silicone leads.
Multimeter mode has reasonably quick response to voltage change, and quick continuity.  Oscilloscope mode allowed me to verify some SPI clock and data signals, this was just slow SPI at 125kHz for RGB LEDs.
It took me a while to work out that the MENU button can be used in DMM mode to clear measurement statistics.  Also I had to do a calibration in Scope mode to clear a 1div voltage offset which was messing up the measurements and trigger value.
One other thing that I noticed is that the units are in the bottom right of the display separate (and far away) from the readout value.  So in certain modes like resistance you have to look there to see if the reading is 1 ohm, 1k, 1M, etc.
Offline Texnik
  • Country: ua
« Reply #4 on: February 12, 2024, 04:17:14 pm »
In oscilloscope mode, can the red beam be changed to another color, for example yellow?
Offline Texnik
  • Country: ua
« Reply #6 on: February 13, 2024, 04:50:28 am »
In the topic that you indicated there is a similar question but there is no answer
Offline Kean
    • Kean Electronics
« Reply #7 on: February 13, 2024, 08:58:30 am »
There are very limited settings, and nothing to adjust the trace colour (or color  :D).
Offline kvazmatik
  • Country: sk
« Reply #8 on: April 09, 2024, 08:57:59 am »
I bought one recently, but I'm not sure about voltage rating on scope. That 300V is P2P or Rms?
Offline Kean
    • Kean Electronics
« Reply #9 on: April 09, 2024, 12:33:47 pm »
DC+AC peak.  So in theory for LF AC only, 600V P2P.
https://www.eevblog.com/forum/beginners/what-does-(dc-peak-ac)-actually-mean/
Obviously you have to derate that spec significantly for higher frequencies as it is just using DMM probes.
  • Country: no
Offline tlex
« Reply #11 on: June 01, 2024, 01:21:37 pm »
Anyone knows if there is a support site for this unit ?
Got mine yesterday and I have a few questions... maybe you know !
In the menu settings,
What APO mean ?
What firmware are you running ? Mine is at 1.2.12
How do you turn off automatic power off ?
Offline 4thDoctorWhoFan
« Reply #12 on: June 01, 2024, 01:57:12 pm »
What APO mean ?
Your last question mentions auto power off & your first question mentins APO.  Auto Power Off??
Perhaps you answered your own questions.  That's it, I know nothing about this product.
Offline tlex
« Reply #13 on: June 02, 2024, 05:55:11 pm »
Nah, I tried switching APO but that does nothing :(
Offline ElEdu
  • Country: ar
« Reply #14 on: July 18, 2024, 11:58:32 am »
Bside support responded to me:
Dear Eduardo,
Thank you for contacting us.
Please download the firmware update for BSIDE O1 Oscilloscope from the
following link:
https://www.mediafire.com/file/h4gmy1sl5titaqn/FW-V1218.O1/file
Feel free to contact us for any questions.
Regards
Michael
