I have the Fluke 189 and I don't find it's continuity feature is anything special. Just the beep doesn't sound good to me.
Quote from: nctnico on July 17, 2024, 09:51:50 pmI agree. For me continuity must be instant otherwise I start to wonder whether the probes are plugged in OR which one of the past 5 points I tested actually had a short. In bench DMMs it gets even worse compared to handhelds. I've been looking at a whole bunch of these (including the ones from the A-brands!) and so far I have found only two with instant continuity: VC8145 and UNI-T UT8805E.That's because bench meters usually do not use a dedicated multimeter chipset that has an optimised continuity function. It traditionally just uses the high resolution dual slope integrator and implements a software continuity function.Newer ones are better:The Keithley DMM7510 is instant and latched, but it's got this weird buzzer type sound which is kinda strange.The Keysight 34470 is also instant and again latched and has a much nicer tone than the keithley.
